Recommend Supplier for Oil Change and How to Fix Road "Dings"
Old 07-23-2012 | 01:39 PM
caymanrgr's Avatar
Awaiting Email Confirmation
caymanrgr is infamous around these parts
Love my 2007 Black on Black Cayman S which I purchased in Tampa after a year overseas
1) Who do you recommend for purchase of filter for oil change & what oil weight for a car that is now in Connecticut v Tampa.
2) Unfortunately I hit a spot on the highway where there was road resurfacing going on and I have a few chips on the front trunk. Ideas on how to touch up?
Thanks!
Old 07-25-2012 | 02:36 PM
ECS Tuning - Porsche's Avatar
@caymanrgr Congrats on the purchase!! I would go with the factory recommended Mobil 0W-40 (ES2499526). With many different choices in oil filter I tend to lean towards the K&N oil filter (ES2535598), they seem to be built a little better then the rest.
Sorry for the misfortune on the highway, if you can get us the your paint color, I can source you some factory touch up paint. Afterwards possibly looking at investing in some Lamin-X Paint Protective Film (ES1871805).
Old 07-25-2012 | 03:41 PM
POOR-SCHE's Avatar
POOR-SCHE is infamous around these parts
Just did my oil change on my 2008 Cayman S...Walmart [ mobil 1.. [0-w40]...Pepboys oil filter..[purolator]...[ 11.00 bux..]..
Old 07-26-2012 | 06:53 PM
Macster's Avatar
Thanks!
Buy the filter at your local Porsche dealer. Be sure to get the drain plug seal ring and o-ring for the filter housing.
For oil, use any approved oil. Unless things have changed recently Porsche doesn't approve any 10w-40 oil.
Mobil 1 0w-40 oil works very well but there are plenty of 5w-40 and even one 5w-50 oil approved for use in these cars if you do not want to run Mobil 1 0w-40.
If you drive your car in the winter in CT you might want to use Mobil 1 0w-40 oil for Porsche recommends it if ambient temps drop low, down to IIRC -25C which is -13F. CT might see that cold of winter temps.
If you want to know which oils are approved you can visit your local dealer and ask the tech to print out a copy of the approved oils list. My tech does this for me every year or so when a new list comes out.
Or look for 'A40' on the oil bottle which means the oil is approved for use in your car's engine.
Sincerely,
Macster.
Old 07-26-2012 | 07:02 PM
the_vetman's Avatar
the_vetman has a spectacular aura aboutthe_vetman has a spectacular aura about
Yeah, I was going to comment on that when I first read it but I think it's just a typo.. because when you click on ECS' link it shows Mobil 1 0w-40 and not 10w-40.
Preference of oils is such a controversial topic but - as Macster said - there is a long list of approved oils. Saw the list online somewhere but I've forgotten where... OP, get 0w-40 (Euro blend) since you live in CT.
As an aside for any newbies: heed Macter's advice. He knows his stuff.
Good luck.
p.s. In the past I've found Mobil 1 0w-40 at local Wal-Marts for $6.49/quart (one of the cheapest prices I've seen). Had to go to 2 different locations (1 near work, 1 near home) as they didn't have enough.
Old 07-26-2012 | 07:36 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Personally, I buy oil filters from Pelican Parts, or one of the many board sponsors here. The dealer sponsors here typically offer the kit at a relatively reasonable price. Pelican sells the oil filter for $11 - 30, including new filter, o-ring, and compression washer. As for oil, I've been using Castrol 5W40 - I typically buy that when they have sales @ Autozone, Adv Auto Parts, or Pepboys.
As for paint chip.. I've heard dr. color chip works.. though I have no first hand exp on this.
Old 07-26-2012 | 08:46 PM
the_vetman's Avatar
Oh yeah... Fix It (used to be on TV) works really well though I've found that it's not permanent. Just a very good short term solution.
COBB Tuning
01-29-2022 09:42 AM
SharkyShark20
09-19-2015 09:54 PM
BLKonBLK911C4S
NorCal
08-29-2015 03:20 AM
gulf gt
08-27-2015 10:27 AM
00aston
08-27-2015 12:01 AM
Quick Reply: Recommend Supplier for Oil Change and How to Fix Road "Dings"
