Stalling
A problem is if the stalling is due a malfunctioning fuel pump the pump may not quit outright but just fail intermittently.
I'd advise you to take the car in and get a pro tech's opinion. Maybe there is a test or a check that can be made (or possibly a check for any error codes) to confirm the stall was due to a fuel supply problem and perhaps can determine which pump was the culprit?
