1 Set of JIC Coilovers on Clearance
Old 12-28-2006 | 02:43 PM
vividracing's Avatar
Hey guys, I have 1 set of Cayman/987 Boxster JIC Cross Coilovers available on Clearance. You can buy them through the EBAY store or PM me directly.
CLICK HERE
The Cross Competition coilover system features a light weight, 15 way adjustable monotube damper that ensures high strength and fade free performance. The ride height is adjustable separate from the spring perch giving you maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings.
-The coilover system includes:
-front and rear coil-over shocks.
-upper pillow ball mounts on the rear.
-front camber plates for up to -3 degrees of camber adjustment
-coilover collar wrenches.
-compression/rebound adjusting tool.
Old 01-04-2007 | 02:22 PM
MoeMonney's Avatar
MoeMonney is infamous around these parts
How do these compare to the Bilstein Pss9?
Old 01-04-2007 | 02:27 PM
much better. 15 way adjustability in dampening, camber plates in the front and pillowball mounts in the rear, monotube shock design for faster reaction. Adjustable ride height. I have setup numerous cars with these, give me a call to discuss.
Old 01-07-2007 | 08:09 PM
987bs's Avatar
987bs is infamous around these parts
are they PASM compatible??
Old 01-09-2007 | 12:48 PM
Your PASM will still work!
Old 01-09-2007 | 03:10 PM
Brucem's Avatar
Senior Member
Brucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to all
great great setup!! my buddy has them on his Boxster... just awesome
Old 01-09-2007 | 07:56 PM
post some pics bruce!
Old 01-09-2007 | 11:25 PM
David_J's Avatar
David_J is a glorious beacon of lightDavid_J is a glorious beacon of lightDavid_J is a glorious beacon of lightDavid_J is a glorious beacon of lightDavid_J is a glorious beacon of light
Here you go. Best mod I have done. Made a huge difference for autocross. Bruce being the more experienced autocross driver noticed a huge difference. He used my car at a couple of events last year. Once without the suspension, and once with it.
-David
Old 01-10-2007 | 10:30 AM
sweet pics!
Old 01-10-2007 | 04:22 PM
Brucem's Avatar
Senior Member
Ya I cut off over 5 seconds with this setup on the course.... great suspension!
Old 01-10-2007 | 06:32 PM
David_J's Avatar
That's because you stopped hitting cones.
Old 05-26-2007 | 04:26 PM
Anyone want these? I still have them. PM me or email.
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
PelicanParts.com
964
08-18-2015 03:57 PM
PelicanParts.com
964 Turbo
08-18-2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
08-18-2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
08-18-2015 03:55 PM
Quick Reply: 1 Set of JIC Coilovers on Clearance
