**TechArt Cayman From Exotica Motorsports**
Upgrade your Cayman Porsche with Products from Exotica Motorsports!
1. Mirror inserts
Black $199
Silver $299
Carbon fiber $429
2. Interior
Set of floor mats LHD
OE carpet with leather piping (Specify carpet and trim color)
2-pc set $398
2-pc set BOSE sound system option $398
Embroidery, each mat $89
3-spoke sport steering wheel
370mm ergonomically shaped leather covered w/ perforated leather at 3 and 9, hand stiching, fits OE airbag & multifunction
Type 1 black $1,950
Type 1 color as desired $2,150
Type 1 color / carbon $2,550
Type 2 black $1,950
Type 2 color as desired $2,150
Type 2 color / carbon $2,550
*refundable steering wheel core charge -$600
Aluminum pedal kit
with TECHART logo
3-pc kit (manual transmission) \ $369 \
2-pc kit tiptronic \ $369 \
Aluminum foot rest
with TECHART logo
LHD vehicle $209
Door sill kick plates
Dull with polished "TECHART" logo $569
Illuminated "TECHART" logo $1,529
Aluminum shift ****
incl. leather boot $539
Carbon-Kit I $2,299
-panel 3-pcs cupholder
-panel 2-pcs dashboard
-switch panel
Carbon-Kit II $1,399
- Door trim L/R
with TECHART logo
2-pc kit
3. Suspension
Spring kit
lowers ride height 25mm $549
Coil over chassis "vario" $4,490
(No PASM version) improves handling andresponse, adjustable ride height,4 sport spring kits(Main & helper springs),4 adjustable shock absorbers(adjustment of compression &rebound)Lowers ride height up to 30mm
Coil over chassis for "PASM*" $4,990
*(vehicles with PASM) improves handling andresponse, adjustable ride height, 4 sport spring kits(Main & helper springs),4 adjustable shock absorbers(electronical adjustment ofcompression & rebound)Lowers ride height up to 40mm
Anti sway bar kit $1,420
Front/Rear adjustable
Strut brace $489
Aluminum version
4. Side skirts $1,299
5. Brakes
Steelflex brake kit $599
Sport brake system call
6. Frontspoiler I $1,239
7. Formula Wheels
Formula 18"
8.5x18 +50 silver $799
8.5x18 +50 GT matte black $899
10.5x18 +42 silver* $899
10.5x18 +42 GT matte black* $999
Formula 19"
8.5x19 +48 silver $999
8.5x19 +48 GTS gloss black $1,099
10x19 +40 silver $999
10 x19 +40 GTS gloss black 986 $1,099
11x19 +52 silver** $1,099
11x19 +52 GTS gloss black** $1,199
Formula 20"
8.5x20 +52 brilliant silver $1,199
8.5x20 +52 GTS gloss black $1,299
11x20 +55 brilliant silver** $1,349
11x20 +55 GTS gloss black** $1,449
Formula II 19"
8.5x19 +48 silver $1,179
8.5x19 +48 MER anthracite $1,339
8.5x19 +48 GTS gloss black $1,339
11x19 +52 silver** $1,489
11x19 +52 MER anthracite** $1,649
11x19 +52 GTS gloss black** $1,649
Formula II 20"
8.5x20 +52 brilliant silver $1,399
8.5x20 +52 MER anthracite $1,559
8.5x20 +52 GTS gloss black $1,559
11x20 +55 brilliant silver** 097$1,649
11x20 +55 MER anthracite** $1,799
11x20 +55 GTS gloss black** $1,799
* 7mm spacer kit for rear axle required $359
** 15mm Spacer kit for rear axle required $429
** lowering springs required $549
8. Rear spoiler type I $599
improved aerodynamics fits OE rear apron, PU-RIM
9. Exhaust
Carrera GT Style exhaust system $11,619
Stainless headers, high-flow catalysts, stainless exhaust with bypass valve, exhaust tips, electronic valve control
Sport exhaust tuner w/tips $1,499
(sporty sound) galvanized steel-version
10. Drivetrain
TECHART Sport air filter $279
Foam & metal version, washable
Short shifter $799
reduces shifting 20%
10-06-2015 06:13 PM
