Carbon Ceramic brake questions
Hi all--I'm looking at a used Cayman S that is equipped with PCCB's. I have read extensively about the pros/cons of these, but I still have a couple of unanswered questions.
1) Is it possible to replace the ceramic rotors and pads with steel rotors and compatible pads? I might track the car extensively, and I'd like to be able to select pads based on my preferences for initial bite, ultimate torque, release characteristics.
2) Is there a market for lighly used (meaning well within spec) ceramic rotors, pads, and calipers.
3) With the CCB system, is the booster, master cylinder, valving, etc. the same?
Thanks.
Scott
Thanks.
Scott
I believe on the 997 the steel cup car rotors are a direct swap but I do not know if that would mean they would also fit the Cayman although they are supposedly the same.
As far as resale, I would think someone would want them. The only downside is if you sell the car and potential buyers wonder where the factory PCCB's are.
04-28-2022 12:38 AM
