EPS Drive Shaft Clamping Center Support Now at Pelican Parts!
Old 12-30-2013 | 05:47 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
The driveshaft center bearing support is used to dampen vibration and lateral movement of the driveshaft as it spins. The factory design of the rubber seems to be a bit weak for the job, usually resulting in the rubber cracking or tearing due to age and the elements. When the rubber starts to fail, you'll notice an odd vibration coming from the center console when accelerating. This vibration will only get worse over time, eventually turning into a loud knocking noise.
The factory fix for the support is to remove the driveshaft from the car, disassemble it and use a new center support (with the same rubber centered design) when reassembling it. EPS has devised a solution that does not require driveshaft removal, and does a better job of supporting the driveshaft.
We’ll walk you through the steps when replacing the driveshaft bearing support and flex disc – instructions here!
Shop now for the EPS solutiondetails here!
Let us know what questions you have at any time.
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
08-20-2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
08-20-2015 02:59 PM
08-19-2015 06:35 PM
Quick Reply: EPS Drive Shaft Clamping Center Support Now at Pelican Parts!
