Cornering lights not working
Old 10-24-2013 | 09:07 PM
racer_65's Avatar
racer_65 is infamous around these parts
It's damn annoying that these cornering light bulbs go out on the Cayenne. I have a 2000 Nissan van with cornering lights that are still working great. Why does Porsche use these low quality light bulbs? Several other light bulbs on the car have gone out at various times as well, such as the side marker bulb, rear brake bulb, and turn signal bulb.
It's also surprising that nobody makes a H3 LED bulb with a built in resister to overcome error codes. I'd hate to ever replace these bulbs again.
Old 10-25-2013 | 11:21 AM
ciaka's Avatar
when you replace, I recommend being very careful once you pop the headlight out.
If your car is not near brand new, you will notice that the internal wiring (inside the headlight assembly) is very brittle, to the point that if you touch some wires, the shielding will flake off exposing metal, which will cause strange electrical effects. I was unable to find any place where they would sell the replacement for such harness inside the headlight assembly (they do sell the one for outside the headlight - one that connects to the headlight).
So when opening, replacing, closing, be careful not to touch any wiring. Good luck.
Old 10-30-2013 | 09:53 PM
Waitin4Dv's Avatar
Waitin4Dv is infamous around these parts
My driverside cornering light went out and my passenger cornering light still works.
Old 10-31-2013 | 07:45 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
That's unusual. What year is your Cayenne?
Old 10-31-2013 | 08:37 AM
Waitin4Dv's Avatar
Its a 2006 turbo s. When I turn to the right the cornering light comes on, when I turn to the left it doesnt come on. My instruments says check left cornering light.
Old 12-29-2013 | 02:53 PM
Porn_Star's Avatar
Porn_Star is infamous around these parts
THANK YOU!
I only got my Cayenne last Sunday and this forum has been very useful. This particular post gave me the courage to sort out my right cornering light!
until on my way home the left one blew.... oh well 10 min job!
cadman
10-04-2023 01:36 PM
gulf gt
08-27-2015 11:27 AM
TrackOne
08-20-2015 01:56 PM
Walorus
08-18-2015 02:39 PM
