What will happen if i fill a cayenne with leaded petrol?
I know most of you wouldn't even want to think about answering this question but i'm curious. What would happen if you fill your cayenne up with leaded petrol? What' the most likely thing and the worse possible thing.
Cheers
Cheers
I don't think you can force the gas nozzle of an leaded pump down an unleaded neck. They made them smaller so you can't make that mistake. Also didn't Europe and many countries ban the use of leaded fuels? I don't think you can get it anymore.
If you were able to fill it up you would burn out your catalytic converters and render them useless.
It's not an uncommon practice to use leaded fuel these days what so ever.
"A fuel deflector and restrictor are disposed in the filler neck of an automobile fuel tank to inhibit filling of the tank with improper fuel. An opening in the restrictor permits insertion of and delivery from a fuel nozzle used with non-leaded fuels, but the restrictor obstructs a larger diameter nozzle used with leaded fuels."
ok thanx for the answers guys... so all i have to worry about is the catalytic converters and the o2 sensor.. nothing major in my eyes. Is there a way round the cat damage? like if i fit a straight through pipe would that work? (no law here to stop me from doing that btw). Also, when the 02 sensor goes, how can i tell? would the car start driving funny or is it a matter of 'check engine' warning light?
Correct me if i'm wrong but doesn't the bypass pipe replace the cats? if yes, would a fabspeed bypass pipes sort out the cat problem that i'll have from using leaded petrol?
I've never checked but yeah if you use the bypass pipes and they circumvent the cats then problem solved.
When the O2's go, you will likely get a check engine light and it will run very rich. You will know something is up.
That being said it will take a couple hundred gallons of heavy fuel before you even begin to notice an issue.
Lead was used as a lubricant in the valvetrain, not really needed anymore with hardened valve seats. "lead poisoning" of oxygen sensors tends to make them lazy over time, they dont switch as quickly. Why would you want leaded fuel anyways? there are plenty of high octane non leaded fuels out there.
(edit: didnt notice youre from yemen until after I posted.... not sure about availability of fuels in your country)
The availability of fuel in Yemen is low... We have oil (and good quality) but most of it is exported (oh... great.... but what do the local people do )
EMC2
Cayenne 955/957
09-07-2015 05:20 PM
PelicanParts.com
08-26-2015 03:10 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
