Brake pad install
Old 01-27-2008 | 08:51 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
Brake pad install
Just finished installing brake pads, front and rear 1 1/2- 2 hours tops, for only $300 (pads only, rotors still good) Can't believe I paid $600 for just the front at the stealer. Probably the easiest pad install I've ever done.
Got the parts from SunCoast; great prices and service.
Old 01-28-2008 | 06:18 PM
seattle_sun's Avatar
seattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really nice
Is it the same as switching out the pads on the 911?
Old 01-28-2008 | 08:32 PM
SoCal955's Avatar
Same thing, unbolt and slide out the retaining pin, take out old pads, compress pistons and slide in new pads. EASY.
Old 01-29-2008 | 06:49 AM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
I thought there were some consumable parts that need to be replaced also (wear sensors, springs/clips, etc.). Does the piston compression require a special tool also?
Old 01-29-2008 | 10:17 AM
To compress the piston, just use a channel wrench to squeeze the calipers. Just buy new wear sensors to clip into the new brake pads or you can try to pop out the sensors from the old pad.
Old 01-29-2008 | 09:34 PM
SoCal955's Avatar
You need the new sensors, the old ones will be shot.
Old 01-31-2008 | 12:27 AM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
I'm trying the Hawk LTS pads this weekend, supposed to be great and no dust!! ok a maybe a little
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
awchristler
Bentley
08-24-2015 03:53 PM
ECS Tuning - VW
08-20-2015 03:07 PM
Quick Reply: Brake pad install
