Cayenne S getting slower sometimes why?
Guys,
Today, I am pretty sure, positive about this fact and I want to know the reason of this problem. My CS gets slower than usual sometimes. When I kickdown around 17mph at 3rd gear, my cs is used to push me so hard, but sometimes it doesn't, and today was one of those days and after turning my car off for dinner and after dinner, I started my car up again and it was perfect. Why do you think is this?
Was the car cold ?
This is pretty normal especially if your water and oil levels are under the ideal temp's. Next time try pressing PSM OFF to turn the car into a sport settings and dont forget to click on the sports button for both the suspension and the PDDC.
The car was not cold, it was running on the desired temperature which is around 180 degrees fahrenheit and oil temp was around 200F. It has nothing to do with the engine temperature nor the sport mode since the sport mode was active and psm was off when I decided to open this thread. But thank you anyway
Guys,
A little experimenting with PSM off does the trick!
meanmachine, i guess what you are talking about is different because my car does the same, downshifts to even 2nd gear from 5th gear if i am in sport mode, however, what I am talking about is when it shifts down to 2nd gear, this is where I feel the difference. It always shifts down, but sometimes I feel a strange difference between car startups...
Unfortunately most of the driving done everyday is not "Speed Racer" type, so over time it will learn how you drive. All you have to do is step on it once in a while. The old adage of babying it till broken in is not necessary in newer vehicles, "Drive it like you stole it" is how a new vehicle need to be broken in.
