Will powerbreaking give damage to car?
Old 02-18-2008 | 11:25 PM
canberk's Avatar
canberk is infamous around these parts
Here is a good question, will powerbreaking give damage to our cars. I think it may affect the transmission as the car is applying force to it but the brakes are holding the car still. It may also damage the engine for the same reason. I don't think it affects the brakes that much as because they used to have that load all the time.
Old 02-18-2008 | 11:55 PM
MeanMachine's Avatar
I think it will only wear out the brakes because the brakes are trying to hold the car still.
Old 02-19-2008 | 09:32 AM
LAZY TURBO's Avatar
LAZY TURBO is infamous around these parts
^^ exactly.
Old 02-19-2008 | 10:32 AM
Vladcanada's Avatar
Vladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of light
clutch?
Old 02-19-2008 | 01:20 PM
canberk's Avatar
i think it damages the car... especially the clutch
Old 02-19-2008 | 01:47 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
How many times are you planning on doing it? I shouldn't do anything if you only try it a few times. But if it is every stoplight, you would probably run into some sort of brake or tranny issue.
Old 02-20-2008 | 02:11 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
There isnt a clutch. It uses a flywheel and torque converter, which uses a fluid to transmit power(the reason for so much drivetrain loss). Basically, you put more stress on the internals of the transmission. You dont do anything to the brakes because unless you are moving, they dont wear down.
PorscheEnthusiast
11-13-2015 02:23 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
gulf gt
08-27-2015 10:27 AM
08-21-2015 06:34 AM
Gewgaw
08-19-2015 11:52 PM
Quick Reply: Will powerbreaking give damage to car?
