Custom bypass pipes??
Ok...so I went to a local welding/exhaust shop and they wouldn't touch it. Say its illegal to remove cats?? It seems true, but these are secondary cats. Does that make any difference? How did people get theirs on their car.., some must have installed them at a shop. And if so, how come they didn't bring that up?
ErikG
How did those pipes work out?
Hey im out here in Newcastle. I have an 05 S and im probably going to swing by a few shops tomorrow to see if someone can make them for me. I will let you know.
Most shops won't touch it unless performance oriented. The shops that won't, will probably ask you to tow the car in and tow the car out after completion (ie. track) Most muffler shops don't want the liability because it's a huge fine to them.
They don't care that you still have another set of cats. A cat is a cat to them.
I ended up purchasing a used set of Fabspeed Bypass pipes on the board here and had it installed at a local shop. The Cayenne NEEDS bypass pipes.. the sound is so much better than just an exhaust mod. I liked my magnaflows.. but w/ the bypass its killer. And in the car you just hear a rumble, not loud. Outside the car is another story,
Sorry to raise the dead thread here...
I shipped my SuperSprint Muffler from my Cayenne over to the States as I was not using it. Installed it on my Touareg V8 in the states and had the resonators removed.. Sounds awesome!
Question, I am just considering bypassing the muffler.........cat deletion is too raspy in my opinion.
What would the lack of mufflers sound be deeper and less raspy too???? nothing on youtube so far.
I think remove second cat should not be a problem. Any professional muffler shop can make bypass pipe by request. It's just a pipe.
I order mine with rear exhaust.
I got some custom by-pass pipes installed for $150 along with hangers that use the factory mounts. Sound difference isn't as noticeable as people claim and as for power benefits, not that awesome either. Of course I can see how this might be better for a turbo model, I just have the S. When I did cat deletes in my WRX, I felt and heard immediate improvement.
Legally, you're only required to have '1' Cat. Most companies use the 1st down the line ONLY because they need to get hot to work properly. The 1st Cat is only useless for 1 minute... after that, the 2nd down the line is hot.
Its stupid.
So, which are folks by-passing anyway ? 1st or 2nd down the line from the block ?
Its stupid.
Oops, I meant the 1st Cat is only USED for 1 minute !
Why can't we edit our own posts anyway ?
Its stupid.
Its stupid.
