Cayenne tires worn in 8000miles...
Hello guys,
I've put 8000 miles today to my 08 CS and front tires are worn completely. Is that really normal? I have the 19" Continental all season tires that came with the vehicle.
I got 10K out of 275/40ZR20 Pirelli P Zeros on my turbo. Just re-shoed with Michelin 275/45R20 Latitude Tour HP and love them. They ride a ton better and they have a 440 treadwear compared to 220 on the Perillis. They should go 20K.
That sounds a little to fast for the fronts to wear out. You might need an alignment if the wear is uneven. If you have air suspension the alignment process is quite involved, takes a couple of hours to do it right, as it has to be checked both on the normal and lower ride heights. Make sure you take it to a place that has the specs and knows what they are doing.
Yes. 1hr tops.
04-28-2022 12:38 AM
horsepowerfarm
09-10-2015 06:09 PM
PelicanParts.com
08-26-2015 04:25 PM
PelicanParts.com
08-26-2015 04:24 PM
PelicanParts.com
08-20-2015 02:57 PM
