Parking brake light stays lit
I had an issue with the parking brake light staying on last night. I pushed the brake back in several times thinking it would pop the brake out 'just a little more' and trigger the light to turn off but it didn't work. The light stayed on and it beeped at me the whole ride home (only about a mile). This morning the light was off and all has been well so far. Any ideas or similar problems?
Try to reach down while you pull the release and see if it will come up anymore. If so, you need a new "return shock" or whatever it would be called. Mine was replaced under warranty as it was getting weak (along with the rear gate shocks).
This is the one problem I have. The solution is simple- lift the parking brake pedal up a little and it will shut off.
When I get some free time I'll get under there and fix it myself
ya, it happened to me once, just use your foot (or hand) to pull it towards you a little bit more... it seemed to just get a little stuck and not fully fully release... hope that helps...
there was a recall on those hinges
I just looked up the receipt and the part no. is 955-423-052-06
