Lowering Cayenne Turbo
Hiyas folks!
I got a 2003 Cayenne Turbo, but for some local tax laws here in Asia, they limit the height of the car. Basically i cannot lower the car to the lowest settings on the car. Is there a way around it using vag-com?
TIA
TIA
Interesting... I have a vag-com for my S4 and never plugged it into my cayenne. I spoke with Vag-com a while back and they told me it couldn't be done with their product. He did say however that the Durametric tool probably can lower it. I believe you can lower the VW Toureg only with the Vag-Com.....
I just ordered the lowering links from http://www.adjustableairride.com/ I should have them next week and I'll let you guys know how the install goes. I've been on the lookout for a used module and just could not find one. I helped my brohter install a renntec lowering module on his E63 and it was fairly straight foward. Took us around 3 hours beginning to end. I believe the install is similar on a CTT so it would not be hard to figure out.
What's the lowest setting it allows while driving? I have the TechArt module and I can only drive in the 'Low' setting. When I lock the CTT the module drops the car down to the 'Loading' level...I assume b/c it looks cool. I'd love to be able to drive around in this setting. Can I add the lowering links and still retain the TechArt module?
I don't know the answers to your questions. I went with Rinspeed because the Porsche dealer I bought the CTTS from recommended that one because it was the least expensive (about $1500 installed as I recall).
I recommend you call Rinspeed with your questions. Their US office is in Florida.
i am running the adjustable links.
very happy with the purchase. it does take a little bit of time tweaking to desired height during install but after you figure one corner it is practically effortless.
i keep my ride set to the low level which is approx loading level before
ride quality is good
i have not driven a CTT w/ a lowering module so i cannot compare but assume ride quality would be the same as you are are riding on the same shocks.
