best lowering module opinions
i have noticed the bumpiness at this level as well. i am also running 22's. i have heard no issues about ride quality from any of the lowering modules. although the car is riding on the same shock it must adjust pressure in them or something. i will likely purchase a module at a later date. but have other priorities in the near term; winter rims/tires & bypass exhaust
The lowering links basically compress the air shocks more, which causes higher cylinder pressures(think lowering spring effect) whereas the lowering module drops cylinder pressure (shortens cylinders) and gives a lower ride height.
does anyone know if the adjustable links will cause damage to the current shocks due to the increased pressure/bumpiness?
All the kits should really do the same thing - just get the computer to run the car at a lower ride height. The air suspension is what it is - at normal ride height it's fine but you will hit the bump stops more the more you lower it.
You can lower it for free if you know someone with a VAG COM programmer, you just change the stored numbers for each corner's ride height. Not sure why people are paying for these kits or arms when you can do it for free. Maybe the Porsche can't use the programmer, only the VW?
adnanm3
11-22-2023 02:43 AM
proTUNING Freaks
09-15-2015 07:28 AM
