Air suspension warning , but works fine?
Old 08-24-2008 | 09:17 PM
motoadve's Avatar
motoadve is infamous around these parts
Today I got the air suspension warning this morning.
The air suspension is working fine, rises and lowers the car , stays at the height I program , suspension feels fine.
Took a 150 off road trip (was the plan when I left the house and when I got this warning).
Warning kept coming on during the day, not inmediatelly but sometimes after 5 minutes other times after 30.
Drove the hell out the cayenne today, and worked awesome, technical steep climbs and descends, rocky roads, fast , slow, and the car and suspension felt great.
So any ideas what could this be? I get the warning but works fine.
Has this happened to anyone else?
Its a Cayenne S 2004, do you guys know if there has been a recall for this in 2004 model?
Old 08-24-2008 | 09:24 PM
canberk's Avatar
canberk is infamous around these parts
What is the alarm message? Chassis system faulty? If so, then the problem is with the air suspension module that can be found at the rear trunk. Either get a lowering module that will fix the problem, or go to local stealership to have your susp. module replaced for a couple grands.
Old 08-25-2008 | 06:08 AM
motoadve's Avatar
AIR SUSPENSION FAULT WORKSHOP
Old 09-01-2008 | 08:29 PM
PTEC688's Avatar
PTEC688 is infamous around these parts
It's normally just one of the level sensors. Just have your dealer pull the code. I wouldn't jump right into thinking it's a module.
Old 09-01-2008 | 08:40 PM
motoadve's Avatar
fixed a flat tire and the light doesnt show anymore
Old 10-29-2012 | 04:18 PM
RS38's Avatar
RS38 has a spectacular aura aboutRS38 has a spectacular aura about
I will take this thread to ask, it fits quite well.
my 2005 is claiming AIR SUSPENSION FAULT WORKSHOP since a while and more and more.
lowering works fine, but raising one step takes very long (up to 40 sec.). Car drives normal.
error messages usually pops up just after starting or within first mile.
I would like to DIY, are there some known part # to replace?
thanks alot!
Old 10-29-2012 | 04:36 PM
VIPNiSS's Avatar
VIPNiSS is infamous around these parts
thanks alot!
from your symptons it sounds like its the air compressor not filling up the reservoir as fast as the system would like it too. There is a air compressor rebuild kit and its a DIY.
I am not sure if I can post links to other sites or not but ill send you a PM.
Old 11-04-2012 | 12:44 PM
RS38's Avatar
thank you!
strange thing is that filling tires works very well. and there is no error msg if you alter ride height just after start??
will check that seal kit.
cadman
10-04-2023 12:36 PM
04-28-2022 12:38 AM
The Oss
08-24-2015 08:19 PM
ECS Tuning - VW
08-19-2015 02:15 PM
Quick Reply: Air suspension warning , but works fine?
