New product lowering module
#271
Take a look at the 9ff lowering module... it seems similar to the Renntech and TechArt ones but at only $750 or so dollars. I have not ordered mine yet but it will probably be what I get. It is not plug and play however as you have to wire it in. Not a big deal for me.
David
David
#272
thanks,, do you mean the yellow one on the left or right hand side fuse box or the engine bay one? thanks
#273
im a sucker, i bought this thing and it DOES NOT WORK. i have a 2004 ctt.
if i dont get a full refund im going to jack his feed back up, royally.
---refund given----
---refund given----
#276
I dont know why it wouldnt work on an 04 there's no difference on the pasm/air.. all it does is it plugs on top of the air compressor under the passenger seat...I have exact the same plug on my previous 04,05 and 08 cayenne..lol
put the air susp on loading level then turn in to on position...the air wont go back to normal with the module on,
here's the pics again.. I had no problem with mine... just the error on the screen I only put it on low mode when I do spirited driving or go on car meets.. I gave mine to the guy who bought my techart wheels
#277
thanks for the pics, i installed it just like yours. the valve stem is directly under the
magnetic switch/**** module and it wont work.
untill i saw your pics i thought i had the install rotated the wrong way but i tried the other three ways and no go.
it seems to me the valve stem puts the magnet orentated by the **** too far away from the oem part the valve stem sticks out of.
#278
David
David
#279
#283
Believe it or not but I have heard from several reputable tuners that most of the air suspension control modules for european cars (including Porsche, Audi, Mercedes, VW, etc) are just rebadged H&R units... which of course cannot be ordered here in the USA.
http://www.h-r.com/gb/f_ets.php
#284
