Dension GW500 +BTA1500 bluetooth for iphone
Does your cayenne have a cd changer in the back? I want to reinstall my gw500 at te front so I can have access to the iPod and use my iPhone. I tried installing it behind the nav first but I think my dip switches were wrong. I looped the optical back at the CDC and put it in line but it kept giving me a missing amp error so I went to the back and installed it at the CDC. What were your dip switch settings behind the radio? Or if anyone can help.
Nope, didn't remove the wrong optical cable, it came out of the back of the cd changer and I had looped it there, I just don't think the dip switchs were set and since there's a lack of support for dension products anywhere I couldn't figure it out so I just installed it in the back but would like to run it in the front if anyone has an idea as to what I need to do with it. All the step by step installs I've seen have been with it installed in the back and that was the only option that worked instead of fighting it all day.
I am considering to purchase a Dension 500 with BTA for my car and in Italy the company in charge of the distribution declares that jailbroken iPhone should not work with the Dension equipment. In your forum you mentioned iPhone but I have no idea if it is "regular" or jailbroken. Can you please update me?
I have clearly a jailbroken iPhone and looking forward to have an evidence that it works properly with dension 500 and BTA.
Is it possibile that the iPhone jailbreak affects its BT communication?
ciao
Flavio
ciao
Flavio
As do I. Anyone using one?
10-02-2015 02:23 PM
