Techart Module Install Error?
Hey guys,
I picked up a used Techart module for my CTT, and I'm wondering about the install procedure. I replaced the existing module in rear storage bay and now I've got an error "Air Suspension Error, Workshop". So I uninstalled the module, put the OEM box back in the truck and the error went away.
The strange part is that I unisntalled and reinstalled the Techart module with the same results, but the techart module seems to be working since I was able to lower the truck well below the "loading" level, and I'm able to drive at the OEM loading level.
Is there a certain process for installing the module?
IE: put the key position to Accessory 1, then plug the module in or plug the module in and clear the codes with an OBD2 scanner, or disconnect the negative battery terminal overnight?
Any help would be greatly appreciated.
Side note, I don't think the dealer would look kindly to "calibrating" the suspension whil the CTT sits on the Techart module so that's not an option IMO.
Thanks guys.
Thanks guys.
Worth a try, but I doubt that they'll do much for a used module. Has anyone had luck with them, I seem to recall that their customer service was almost nonexistant?
Honestly, I'm hoping that I'll go out to the car in the morning and the error will be gone. It wouldn't be the first time that's worked for me with modern cars.
Does anyone know if there is some kind of "hard reset" for the Cayennes? For some reason I think it just needs to be reset via OBD2 or by disconnecting the negstive battery terminal for an hour.
Yes, Alex911s is correct. I have talked to both CEC, the North American distributor for TechArt and a large TechArt dealer and you have to calibrate it. I'm installing one next week and my dealer had never installed one before but after looking at it they are willing to do it.
Need Techart Module Instructions
Hi guys, I just bought a used Techart Lowering Module from ebay, but I don't have the install instructions. Can any of you guys PM to me? Thanks so much!
You brought a 5 year old thread back to life! That is incredible, sir.
BTW, the Techart manual is not too help. Just open the rear passenger storage area and remove/replace the identical module. Then you have to have it recalibrated.
Haha! Yes, I'm getting desperate here. I understand it's supposed to be plug and play, but nothing is ever simple in my life. I actually have a cd changer where the air suspension module is supposed to be, and the module itself is below it, in some really tight space. I was pulling on the lock for about an hour until my hand pretty much was bleeding from all the sharp edges. It wasn't fun. I managed to install it finally, but I noticed my back right wheel is a little higher than the rest. So for safety reasons, I will be going to the dealer tomorrow to get it calibrated and aligned correctly. The only thing that worries me is that they seemed a little hesitant about installing it. I'm trying to get a hold of the manual so I can hopefully convince them that it's pretty straight-forward. Basically, I'm trying to make this easy for them as much as possible. Would they need the correct offsets and numbers to do the calibration? I'm guessing the manual would contain the recommended specs by Techart. If you guys have any idea what those numbers are, please let me know!
BTW, I've been obsessing over the mods you've done especially the Turbo S conversion. Do you happen to live in the tri-state area? I would love to checkout your Turbo and have a chat about how I would go about converting mine to Turbo S specs. Thanks for all your help and contribution to the forums!
Thanks - send me a PM and we can touch base.
Thanks for the info. I tried to drop it off the dealer, and they refused to install it because of "potential lawsuits" that may result from this aftermarket product. I am planning to get it installed with an independent Porsche shop, and hopefully it doesn't throw out error codes.
For anyone reading this, it is still on my to-do list, to fully flesh out these instructions and post a thread for all to enjoy
