MPH-Limit???? Main Menu
I don't really understand the econ/rest, and all those other options you have up front.
As for the mph limit, I raised mine from 100, to 130, because I kept hearing that chime a little too often at 100.
ECON button turns the A/C compressor off, which means if the outside temperature is higher than the set temperature, it will just blow the air without cooling, if the air temp. outside is below the set temperature, then it will heat the air up, no matter if you activate ECON or not. REST feature only works in case of the second scenario (where the set temperature is higher than outside temperature)
The rest feature you use after you shut the car off, it runs the heater for the inside cabin. Next time you turn off your car, push rest and it will run the heater to keep the cabin whatever temp you left it. It's for cold climate areas obviously. It runs for about 30 minutes I think.
tried the REST. Left my car it was 23• Outside. It warmed it for 30 minutes. Absolutly amazing feature. Thanks pct. Never knew that.
Rest Button
When you hit the rest button it dosen't turn on until you turn off the car. Its design to keep the air runing for about 5mins if you were just going in and out of somewhere fast. So it dosen't get too hot in the car.
cool idea...going to give it a try.
