Tire & Wheel Capabilities....
Old 01-09-2009 | 10:07 PM
RickyStickers's Avatar
RickyStickers is infamous around these parts
Can the Cayenne handle a 305/45/22 tire on a 22" x 10 Rim...
Or is it better to play it safe and use 295/40/22??
Old 01-09-2009 | 10:44 PM
Cannoli's Avatar
Cannoli is infamous around these parts
Check out Tirerack ... they list tire sizes that require a specific wheel width.
Regarding whether or not a 305mm tire will fit, it depends on the wheel offset. I had 295mm tires on 22" wheels with a 50mm offset (ET) and it appeared that there was more room for a larger tire.
It's easy to calculate - do some research at Tirerack ... measure your existing tire/wheel combo and then do the math. Not rocket science by any means.
Old 01-10-2009 | 04:17 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
That would not work.
You can run 315/30/22, 305/30/22, 295/30/22 or 285/35/22.
I am waiting for the new Toyo's Proxes ST II to come in the 315/30/22 for my new wheels coming.
Old 01-11-2009 | 06:40 PM
the reason I am inquiring is because I loved (Cognac's) setup when he had the CS Black on Black wheel package - he was running 285/35/22 all around, but I think its possible to squeeze a 295/35/22 in the rear
to give it linear alignment with the fenders.... I am also hoping to put the truck low with the KW Coilover set.. I am undecided on the Tecnho's 22 or a thick 5-Spoke Aluminum Wheel.... I drive around North Jersey and the roads are not made for thin tires... the more tire I can get the best I'll be..... My aim was to put at least a 40/22 but I can do with the 35/22....
COBB Tuning
11-09-2015 08:02 PM
oufan2929
11-08-2015 08:26 PM
The Oss
08-24-2015 08:19 PM
Zero911
08-24-2015 06:51 PM
Sterlingc1975
08-22-2015 02:30 PM
Quick Reply: Tire & Wheel Capabilities....
