Removing side skirts (GTS)?
i want to remove the side skirts, go w/ the standard rear mudguard setup. Trying to determine if the removal is a job i can do, or one that should be done at the dealer or bodyshop. Have the new mudguards/arches back from the painter ready to go...
Anyone seen any DIY tips/tricks floating around?
thanks!!
thanks!!
will do (assuming i can get them off in one piece. fyi black)
thanks!!
thanks!!
I just wanted to know if putting GTS side skirts (without chaning bumpers) on S car will look fine.. I do like a look of GTS but will probably get S instead and try to make it look like GTS a bit.
Huh good one, I didn't know one. But the reason I didn't want to deal with replacing bumpers is because I had bad experience doing so on BMW (some things were incompatible etc.), plus paint job not matter how good it is will never be like original pain job.
Lowtush
01-25-2022 10:48 AM
