Magnaflow exhaust questions.. Please help!!
#31
Congrats Ricky! Welcome to the club =)
#32
Sorry for the late reply guys.. But those looking to do Magnaflows, part number 14225 works perfect. As far as tips go, I went with a set on ebay that were 6.5" wide total length. Looks clean, sounds awesome!!! I was going to do bypass, however this is more than enough!
#34
Looking good Ricky! I'll be listing my complete Magnaflow custom exhaust (including Fabspeed bypass pipes) in the classified section next week.
I got a steal of a deal on a Milltek Sport exhaust that was too good to pass up.
#35
very clean and nice install you've got!
I will have mine in a couple of weeks or so and will go the same route.
till then just get that sound clip!
also:
did you allready deleted the 2nd cats? or you still have them?
btw. the youtube file of the Seattle996 isn't what we are up too, cause his was a Turbo! and we know that the NA engine is louder. also from the pictures that I've got he had installed Magnaflow #14215, and he hadn't cat removed!
I have not seen any X pipe on yours system? most of the aftermarket exhaust have a x pipe there made to chill the sounds a little.
thanks.
also:
thanks.
#36
hey Jeff, I got one question:
you stated on your exhaust thread that there is a possibilty to use 18" mufflers. since I live in Europe I cant just go to the shop that you've been to, so a email adress or a contact to ask them if they have a picture with these 18" installed would help me soo much.
I'm woried (as you probably see) about the sound. since I have allready the Fabspeed cat pipes installed, and as you said before the smaller you go with the size the louder you get with the sound! imagine how it can sound on a NA.
thanks a lot.
#37
I highly doubt you could get 18" installed easily... I just put in the 14" and it is a tight fit to have the bends from the factory pipes enter the muffler and still have room to fit the bends for the factory tips. My guess is that an 18" muffler would require custom tips with a tighter bend in order to fit the rear valance... Mine is a 04 CTT by the way.
David
David
#38
thanks a lot.
thanks a lot.
#40
have you had the chance to record the sound yet?
#41
Hey Stickyricky,
Any updates on the system you have...or even better yet, any sound clips? Would love to hear them. I know there's a few on youtube, but it would be nice to compare them to yours. Thanks again.
#42
Hey, i got mine did the same way as yours. it sounds nasty, but a little raspy over 3-4k rpm. If I have to do it again, for sure I'll place an X pipe there. the oem catback has and H pipe, but after removing the 2ndary cats the raspy sound comes clear. my adivise is to use like I said an X pipe juste before the mufflers.
I'll try to get a sound clip of mine.
chears,
Ilie
chears,
Ilie
#43
Sticky, how bout some clips?
BTW...how come cat bypasses are so expensive? 500 bucks to start? You have got to be out of your mind...entire exhaust systems start at 500...
Anyone have any clips on bypassed cats? I'm thinking about it for the performance and just a little more "hello" from the S...
#44
guys correct me if I am wrong but basically you can get Magnaflow, flow master or for that matter.........friggin glass packs installed as long as the muffler shop has the ability to make them bend and attach them to the rig?
Ferrari
08-24-2015 04:35 PM
ritchrwi
08-21-2015 04:36 PM
