tire recommendation for 20" rims
http://www.miata.net/garage/tirecalc.html
Here is a great tool you can see how it would look like, sure it would fill up the wheel well a bit but your speedometer would be affected by this.
"275/40/20 vs 275/45/20
Speedometer reading with non-stock tire is 3.8 too slow.
When your speedo reads 60mph, you are actually travelling 62.3mph."
I wonder,,,,, does this mean you get 2.3miles free (per hour)?
Thanks. Look like the math in both cases is close enough. I most likely would opt for the 45 Series as the 40 series is almost 1" shorter in the sidewall. That's fine for looks but ride . . . .ug.
tstat
11-26-2019 08:58 PM
horsepowerfarm
09-10-2015 06:09 PM
