My exhaust are too loud in the cabin what can i do
Old 03-22-2009 | 08:54 PM
Kingshawn1234's Avatar
Kingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud of
I got these custom exhaust about 3 months ago and now its getting annoying and to loud for everyday driving. When im driving i get a headache sometimes and the passengers complain. Do you guys know what i can do to make it not as noisy. thanks
Old 03-23-2009 | 02:27 AM
al7zin_ad's Avatar
al7zin_ad is infamous around these parts
model of the car?
its full system?
Old 03-23-2009 | 06:21 AM
Precision's Avatar
Precision is infamous around these parts
Dynamat!! I have a 2008 GTS, the first thing I did when I bought the truck was gut the interior and dynamat everything. I'm still running the stock exhaust, but you can't even hear it unless the windows are open.
Old 03-23-2009 | 06:45 AM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
Man up.
LOL! Just kidding - I had the same issue on my 996TT. I ended up having to change the exhaust system. It was expensive to go through two systems but I wasn't enjoying the car when it was too loud and had bad resonance.
Old 03-23-2009 | 09:47 AM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
I don't know how much dynamat would help in this case, you definitely should change back to OEM system if the sound bothers you that much.
All aftermarket exhaust systems would get louder as time goes by, how loud? it depends on personal resistance level.
Old 03-23-2009 | 04:17 PM
Im not to familiar with dynamat what is it exactly? i just did some small research and it said to block the sun from entering the car or sounding leaving ur car?
I got a catback system on a v6 is there anything i can put in the mufflers to make it a little more quiet?
Old 03-23-2009 | 04:57 PM
porscheaudifam's Avatar
porscheaudifam is infamous around these parts
its sound dampening foil film
Old 03-23-2009 | 04:58 PM
do u think it would actually work.. how much does it cost
Old 03-23-2009 | 05:27 PM
pcst's Avatar
It's like a asphalt tar stuff in sheet. The price depends on the place you get and the thickness, too.
Which would be cheaper solution? taking out all your interior and properly install the dynamat versus going back to OEM exhaust? Hard to tell at this point.....
Old 03-23-2009 | 07:53 PM
lovethesport's Avatar
lovethesport is infamous around these parts
remove the cat back--
Old 03-24-2009 | 11:39 AM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
As suggested..Your only option is Dynamat. Any audio store can install it for you.
But it's not cheap,especially if you're looking at doing the complete floor.
Old 03-24-2009 | 12:03 PM
pcst's Avatar
Not to mention that Dynamat is pretty heavy duty stuff, will add a significant weight to your cayenne if entire floor is done.
Old 03-25-2009 | 10:03 AM
Precision's Avatar
Dynamat it self isn't that expensive, maybe $200-$300 in material for your entire floor. The majority of the cost is labor to remove everything, dynamat, then reinstall your interior. I did the floor, firewall, doors, side panels, and roof. I get practically no road noise while driving and you can barely hear rain when it hits the roof!!
Old 03-25-2009 | 10:26 AM
Jeff SD's Avatar
I have a set of Secondary cats if you want them. I'm not sure if they will fit on your V6.
Old 03-25-2009 | 05:31 PM
how much did all that cost? Do u have a catback system or anything? Can u hear the exhaust at all?
Quick Reply: My exhaust are too loud in the cabin what can i do
