12V+ source
12V+ source
Does anyone on here know of a good 12V constant and 12V switched source inside of the cayenne? Im installing a set of headrest monitors in the front seats and need a good source to tap into near the middle of the car. Im hoping that there is one in the center console area potentially before taking it apart to see? Thanks!
and they are excatly the wires that every auto electrician taps into to hard wire a 12v source that requires a constant unswitched power.
just pull the unit apart and tee off into the power/earth.
i would think about 6 or more things run in our cars with unswitched power with no drainage problems
accessory sockets
memory seats
radio
phone
aux heater
hazzard warning lights
interior lights
etc
etc
Thats the thing. This requires both 12V constant and 12V switched as well. My main goal of this post was to find out a 12V switched.
I know that the outlets supply the 12V constant. No biggie, the monitors are being delivered today so Ill poke around the car tonight to see what I come up with.
I would use a cigarette lighter plug on the back of the car, right as soon as you open your trunk on the right side. I installed Dension gateway and used that constant power source. It is very easy to access.
when my headrest monitors were fitted the sparky took the power from the power socket (unswitched) and for a switched supply he used the light from the arm rest light., both down between the front seats.
good luck
good luck
This was actually pretty easy. Only took 3.5 hrs total install time. I was able to tap the 12V constant and the 12V switched and ground all on the power plug harness at the back of the center console.
I know this thread is as old as the internet, but I am having trouble finding switched as well. Where is the power plug harness that you are talking about?
Take the radio out, used those; it has the switched power, constant power, ground (though recommend using frame for that).
ECS Tuning - VW
09-08-2015 12:54 PM
ECS Tuning - VW
09-08-2015 09:57 AM
ECS Tuning - VW
09-08-2015 08:29 AM
ECS Tuning - BMW
09-04-2015 01:52 PM
ECS Tuning - BMW
09-04-2015 01:30 PM
