Name this leak...
taste? ugh..no...I rub a few drops on the paint and if the paint comes off I know it's pentosin ok genius...why don't you help Kevin out
Porsche coolant when seen through a clear container is an orangish pink color.
Its Coolant.
Its Coolant.
and the older you get the more leaks you have to name...don't ask me how I know
can you name my leak?
Hello, I have a leak in the unit between the engine and the transmission, it leaks very fast. It happend when I did a brake boost launch.
It leaks out of the threaded holes at the bottom of the houseing that bolts between the eng and trans.
2004 cayenne s V8 4.7L 80,000 miles.
Hmmmm.....
The only thing between the engine and the transmission is the transmission. If it is transmission fluid, and I suspect it is, it is the input shaft seal that has gone..... It's replacement requires transmission removal I am afraid. However, on early 04 transmissions it is "not" a replaceable part and requires a transmission change....You will have to check the TSB's for this info.
Bob
Sorry, there isn't a TSB for this info. It is dependent on trans serial number. A Porsche dealer will have the required info.....
Bob
