Porsche radio/nav (pcm 2.1) faulty screen replacement tutorial video - how to
Rating: Thread Rating: 2 votes, 5.00 average.
Old 04-12-2011, 09:52 PM
bbywu's Avatar
My LCD finally died.
Thank you for making such a detailed DIY.
bob
Old 04-13-2011, 08:23 PM
simpleman325i's Avatar
simpleman325i is infamous around these parts
Still one of my fav posts.... Rox sure knows his stuff and has saved me thousands!!!
Old 04-13-2011, 10:30 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Thanks guys - I'm impressed that there are other nutjobs like me that will risk taking apart a $1500+ head unit
Old 06-24-2011, 10:15 PM
ebco-ltk's Avatar
ebco-ltk is infamous around these parts
Roxboxxx, Thank you for your excellent posts and detailed step by step instructions.
My screen has been on the blink for a while. Doing a google search brought me to your post and solution. I ordered the screen on Ebay, and spent all of 30 minutes start to finish changing out the screen using your pictures as a step by step guide.
Thank you again !
Old 06-27-2011, 12:27 PM
roxboxxx's Avatar
Thank you again !
30 min - dam a new record!!! Glad it worked out for you. Don't forget to drive by the dealer and fling your old screen at the closest service estimater
Old 07-29-2011, 08:06 PM
Speed Freak's Avatar
Speed Freak is infamous around these parts
Different Screen
Thanks for putting the step by step info, appreciate it. I bought the screen from the ebay guy and its the same one you have, but when I took it apart, mine was not the same one that was send to me. I'm puzzled, and need help. Are there two version of these PCM's. I'll post my picture. Mine is on the left.
Old 07-30-2011, 07:28 AM
roxboxxx's Avatar
It's definitely the wrong one. They sent you what looks like the the pcm 2.0 Audi screen.
Email the seller and show him the pic of yours. You need to get them to swap it out.
I also noticed the same dealer I used, selling a PCM 2.0 screen labeled as a 2.1! They def mixed it up and are incorrect. If this is who you bought it from, definitely get it swapped out!
http://cgi.ebay.com/ebaymotors/TFT-D...#ht_2869wt_948
Old 08-10-2011, 07:16 PM
Newyboy's Avatar
Newyboy is infamous around these parts
Smile Hi - I am here in Australia with the same problem with my 997 - did you solve it?
Can you give an update RomeNewYorkMiam?
Old 08-10-2011, 07:31 PM
Pcm 2.0
I had to return my PCM 2.1 to Potugal, they vendor seems reputable. He is sending out the PCM 2.0, and I'm waiting. Will give more update.
Old 08-10-2011, 07:48 PM
Newyboy's Avatar
Thanks mate I look froward to seeing how you go.
Old 08-17-2011, 06:06 PM
PCM 2.0 Screen put in.
Ok. So after 2-3 weeks of a cavernous hole in the console, the screen is finally in. Looks complete and pretty. But.....it's still doing the same thing of screen being grey and if I turn it off, it goes black. Put all the pieces back together carefully. I throw both hands up! Help!
Old 09-26-2011, 08:06 AM
cayenneS05's Avatar
cayenneS05 is infamous around these parts
Excellent write up!!!! How do you know if your PCM is a 2.0 or 2.1?
Old 09-26-2011, 09:09 AM
roxboxxx's Avatar
If you have a 03 - 04 and its a CD based NAV, its a 2.0
If you have a lat 04 - 06 and its DVD based NAV, its 2.1
Old 09-28-2011, 07:31 AM
cayenneS05's Avatar
Great! Thanks for your help.
Old 02-01-2012, 11:21 AM
cayenneS05's Avatar
Well I finally decided to pull out the unit and switch out the screens. Radio still works, but now the screen stays off and does not turn on. I disassembled the unit 3 times to make sure something was still plugged in from when I put it back together. Any thoughts or ideas? I'm stuck
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Porsche radio/nav (pcm 2.1) faulty screen replacement tutorial video - how to
