20x10 Wheel Question
I was lucky enough to have a friend give me a brand new set of TSW Montage wheels as he is leaving the country. All 4 of the wheels are 20x10, 5-130mm bolt pattern..with a 50mm offset.
Question...what size tires should I run on these??? Could I run a 295/40/20 tire? I am afraid that a 275/40/20 tire will not fit properly on a 20x10 inch rim.
Thanks.
Thanks.
275/45 will go on a 10" rim. The side walls wont flex at all and they are more vulnerable to curb rash which is what you mean? Personally I plan to get a larger size to put more rubber beyond the rims...that is when I replace my wheels! The fronts are the only ones that dont have rash due to the fact that they are 1" narrower than the rear.
Thanks.
Thanks.
Are they chrome? I saw the TSWs on Ebay when I was searching for winter wheels, but all the ones I found were chrome.
The stock GTS wheels are 21x10 with a 60mm offset. Did your friend have them mounted on a Cayenne? I'm wondering how a 50mm offset would look with a 10" wheels.
As far as size, I'd go for a 295 if you can find one that meets your needs.
Bringing this one back from the dead but... anyone ever try a 20x10.5 in the front? I'm trying to advise a customer on it and looking for some information.
Kevin@ModBargains.com
714-582-3330 ext 8009
im getting new wheels, the same width as yours at 20x10.0 and am most likely going with the 295/40/20's. my car is lowered 1.4" on h&r springs, and my only worry is that there'd be a possiblity to rub. but now, i'm even wondering if 295/45/20's would work. i'd love to have a set of bfg kdw2's on the cayenne. anyone have experience with the size?
COBB Tuning
11-09-2015 08:02 PM
STAGGERED M3
09-11-2015 12:00 AM
09-01-2015 03:16 PM
