Performace gains from an aftermarket intake plenium
#31
Eh....not always.
Sometimes Mod "A" only nets 10hp on a stock vehicle and Mod "B" only nets 20hp on a stock vehicle but add them together and they have a greater effect and = 40+hp
Just pointing out that it really depends on the mods, the car, etc. Sometimes mods even take away from each other. Not as simple as saying "mods are not additive"
#32
Do the Cat Bypass pipes give an emissions problem?
I'm already planning to (if I opt to keep my 955 CTT) add the BMC filters and the IPD plenum but being from the UK I'm concerned about the emissions with the bypass pipes and don't know enough about them not to have to ask.
I will have to have my car tested (MOT check here in the UK) annually and dont want to risk problems?
If not doing the bypass with the other two mods be good on their own or a bit pointless without the bypass pipes?
Carl
Carl
I have been told emissions shouldn't be an issue for the U.S., can't speak for the U.K.
I can tell you that since you retain your primary cats, it shouldn't be an issue.
If I had to choose between the two, Cat Bypass pipes (turbo down pipes) would be my first addition. Not only will you increase HP and feel it, your gas milage will really improve. The IPD plenum is just icing on the cake.
#33
Make sure you get before and after dynos of your mods. Otherwise, it isn't going to be very reliable data.
A tune is the one mod that will yield the most gains on these cars. Even a tune, however, struggles to put down the power gains you are claiming from your bolt-ons. I'm not trying to discredit you, just skeptical. I have an '05 CTT w/ Techart exhaust. I've looked into mods extensively back a couple of years ago. A tune and exhaust were the only mods I thought worth the money for the cost/hp gains.
http://www.giacusa.com/new2/products...AC_program.jpg
These gains may seem modest but they are available across the entire powerband.
#34
You have not posted one thing yet that has discredited me but only yourself. Not trying to be an ***, but I have been modifying turbocharged cars for years and I know what works and what doesn't.
It doesn't take much to make turbo cars haul *** and the CTT is no different. The three mods (BMC filters, IPD plenum, and Catbypass Pipes) are good for a solid 55-60 HP to the wheels and about the same at the flywheel.
The CTT is horrendously detuned which is why ECU flashing works so well on these cars. You will get a solid 45-50 HP bump by simply flashing the ECU on a CTT and I think almost any tuner on these forums will vouch for that.
BTW, a 34.4 HP gain with GIAC tuning over stock was probably done a stock Cayenne without any modifications done to it (that's not too good). The ECU Flash should be done last, preferrably after doing turbo down pipes and cat back exhaust. With all exhaust pieces done, you should get a solid 50-60 HP from ECU flashing.
#35
I'm not a newbie to turbo cars. All three cars in my sig are twin-turbos. My '07 997.1TT just finished an 8 month rebuild. We're breaking her in for 1000 miles and then she'll hit the dyno for fine-tuning.
I'm not sure why you keep explaining boost pressure to me since it isn't even relavant to anything I've said or claimed. Of course a flash changes boost pressure. That's obvious to everybody. My point is that you changed a couple of airflow parts and trying to tell me they actually yield more power to the wheels than a flash does. If you look at the differences between our motors and the Turbo-S there are quite a few other changes to net that extra power bump but the MOST significant is the flash.
And you cannot extrapolate power gains AFTER you've done your mods unless you use the same dyno with similar air temps. Since you've worked on turbos I'm sure you already knew that.
I'm not sure why you're taking this so personally but whatever...
#36
I suggest you read Maximum Boost by Corky Bell. Great book on turbocharging.
It's not that hard to get 580 - 600 HP out of a 955 CTT. Anything above this gets a lot more involved and a lot more expensive.
So, if you think about it, adding a higher flowing pair of intakes (BMC, and this is up for debate), an IPD plenum, and getting rid of the crappy secondary cats, this is just another way to make the same amount of HP. The CTT S will also have less turbo lag due to higher flowing intercoolers. The ECU tune on the CTT S is marginal as the car still has 4 cats.
I'm not taking anything personally, I just don't think you know what the hell you're talking about. You also don't have these mods so it's even more ridiculous.
#37
You claim I know nothing even though I have been very active in every mod build of every one of my cars. I am not a performance auto mechanic but I understand plenty about FI basics. I've had two aftermarket-supercharged cars and now the three turbo'd cars I own now. I have some money - more than some and less than others. Your comment on the association between money and brains is highly inappropriate and only shows your lack of civil conversation. You say I show no proof to back up my claims yet you have no before and after dyno (except your butt dyno) with your mods on your car. Who is making shyte up now?
Almost all of the aftermarket tunes on stock 955CTTs yield about 50whp/70wtq (+/- a few depending on tuner). The GIAC dyno is one of the lowest peak gain one I've seen. It is on an otherwise stock vehicle. You are making the claim that a plenum alone nets almost the same amount of power to the wheels as a reflashed ECU on a turbo car. Heck, lets put two plenums on there then!
It is well known that a freely flowing aftermarket exhaust and tune yield the most power/torque on these cars. That's why they are the most common mods done to these cars. I said most tunes yield about the same amount of power you are claiming with just an air filter, plenum and bypass pipes. Until you show me otherwise with a dyno I will continue to be skeptical.
What do turbo-down pipes really have to do with this conversation? Afterall, you're talking about a modification that you don't even own! But since you brought it up, how many people with an Sti or Evo changed out their turbo-down pipes without also getting an upgraded flash at the same time?
Seriously, tone down the attitude. There are people out there that have just as much experience and more than you do in modifying cars. You may know more than me but you certainly haven't shown my anything in your posts to make me believe it. Do a forum search in the CTT section for IPD plenums and aftermarket tunes. I have a competition IPD on my 997.1TT w/ GT3 TB. Makes a difference - but only really in combination with a tune.
#38
My issue with your postings is that you seem to be posting just to post. I see a lot of people just post on boards even if they really haven't researched something or know something about something. Your postings are evident of this and I chose to call you on it. There is nothing wrong with being skeptical on your part (I'm a HUGE skeptic), I just don't see the validity in your skepticism as you clearly don't know enough about this particular topic one way or the other.
Almost all of the aftermarket tunes on stock 955CTTs yield about 50whp/70wtq (+/- a few depending on tuner). The GIAC dyno is one of the lowest peak gain one I've seen. It is on an otherwise stock vehicle. You are making the claim that a plenum alone nets almost the same amount of power to the wheels as a reflashed ECU on a turbo car. Heck, lets put two plenums on there then!?.
So you tell me how I'm claiming that an IPD plenum will make as much HP as an ECU Flash? I never said an IPD plenum alone makes 50 whp, go back and read my posts. Based on your GIAC example, since the flash example made a paltry 34 HP to the wheels, in this case, the IPD plenum would be making nearly as much as the GIAC ECU flash you reference. Most likely it was done with a completely stock car and frankly, that would be pretty impressive.
Also, these cars can make more than 50 wheel HP with an ECU flash, it really depends on what mods have already been done. If the entire exhaust has been modified, you will see even more than 50 WHP in many cases. I have talked to numerous tuners and CTT owners who have done the CTT Flash and corroborate this from their personal experiences.
You're only digging yourself a deeper hole.
What most people don't know is that if an exhaust is good for 450 HP, it's likely good for 500-550 HP. The stock CTT exhaust is actually quite good. The real reason to add an aftermarket exhaust is for looks, sound, and to not impede breathability as mods are added.
I come from the EVO world so you don't want to take it there. No one ever said you would do one and not other so your point is completely moot.
If you stop making trouble, I'll gladly tone down the so-called attitude.
I would have to disagree.
#39
By your own admission you've claimed the IPD plenum makes nearly as much as the GIAC-alone flash. That was the only tune we had been talking about up until later posts. Not sure why you are scared. You said it, not me. You also then go on to restate that you can net greater than 50whp w/ a tune given other mods. Well no ****! If you read back I have been trying to get you to see that most people that bother w/ the plenum, filter and secondary bypass pipes also get flashed at the same time. The flash dynos that I've seen are rarely on stock cars. I can't find a dyno of the mods that you have w/o a flash. Show me one. Until then I can't see why you're arguing me w/ "anecdotal dyno data" as your proof.
By most people's experiences (from this forum which I read up on several years ago) with the IPD plenum on our CTT motors they claim quicker throttle response and smoother acceleration. Rarely do they claim or show anything more than a slight butt-dyno gain. This is why I never went ahead and bought them. I didn't want to mess with the ECU so didn't see any real reason in adding the plenum. From what I've read, the plastic plenum is actually pretty good for stock boost levels. Again, not my words, but people that apparently have looked at the designs. On my 997TT the plenum shows much greater gains due to the poor OEM design. Even then, gains aren't really that significant until you start throwing more boost at it.
You're acting like the basics of horsepower are some secret that only you have stumbled upon and apparently need some special degree to understand. Get over yourself man. It isn't that hard to understand. Air + Fuel = Bang! Wow. Post your dyno when you get a chance. I'm man enough to admit when I'm wrong. Are you? Until then, lay off the caffeine. I'm done.
#40
1. GIAC was the only ECU Flash (or "Tune" as you call it) YOU were talking about. You obviously haven't been reading my posts or you have a logic problem (you probably work for Microsoft).
2. I never said an IPD plenum would make as much horsepower as an ECU Flash (50-60 WHP). You cited some oddball CTT GIAC dyno run that only made 34 WHP. I said in this case (which it would be odd), given the IPD plenum makes 30 WHP (and I completely believe it does), it would be damn close to your freakish and moot GIAC ECU Flash reference.
3. I have been talking about ECU Flashing making 50-60 WHP the whole time so I have no idea why you're so fixated on your GIAC dyno run reference. You don't know specifics about the car under test and you chose the absolute lowest ECU Flash you could reference to make your moot point.
You're simply trying to maintain your over inflated rep points and win an argument you're incapable of winning.
You have confused your own argument which only illustrates my point about you and your thinking.
The truth is people should do their entire exhaust before doing an ECU Flash since this is what they go off of. I have been told this by multiple ECU Flash vendors. I say most people will listen to tuners, therefore I declare your statement above as bunk.
WELL DUH!!! Why would anyone flash their car without CBP, Cat Back Exhaust, and diverter valves??? Now you're borrowing my earlier points to make your points. This is absolute comedy.
Believe it or not, just a slight butt dyno gain is typically about a 20-30 WHP increase. At the core of improved throttle and boost response is gained HP.
From the IPD website:
"Comparing aluminum to plastic. Aluminum no doubt gets hotter faster, but it also gets colder faster. Once the car is parked, the Plenum as well as the entire intake system, experience "Heat Soak". On the other hand, when the car is being driven the intake air being drawn through the intake system actually cools the Plenum more quickly therefore dropping charged intake air temperatures."
In my opinion, this is the real secret behind the IPD plenum's effectiveness. So one can conclude, you absolutely DON'T need an ECU Flash to realize major benefits.
I have said it now 2 or 3 times to you. Filters, IPD Plenum, and CBPs are the best HP producing mods you can do other then an ECU Flash (and other than bigger turbos, intercoolers, TB, and intake manifold). Doing a flash once the car has a fully outfitted exhaust (and the mods above) will only render more HP.
Ummmm, no. Based on that simplified logic, I sincerely hope for you that you never wrench because your engine might just literally go bang and explode!!!
I will post some pleasing dyno results soon.
#41
i cant even read this anymore. fat911, you have taken this personal and that is obvious to everyone but you.
Some of what you say has merit, some doesn't. You claim somewhere in this mess that wheel horsepower and flywheel horsepower gains are "about the same". That is preposterous and makes it evident that you have a knowledge gap.
It isn't possible that the plenum can add the power claimed on its own, period.
I do agree with your thought process of upgrading airflow, in and out, prior to a tune but it is not mandatory and some companies claim70 hp from their tunes...
Heads rarely melt as the piston does so well before they do, thhis is primarily due to the coolant that runs through them and the much thicker deck surface than piston crown... The only time i have ever seen it was due to severe overheating that was accompanied by further driving till the engine was damaged to the point of being inoperable.
aluminum doesn't cool faster than plastic, seriously???
SeattleBum, glad to see you decided to stop trolling this guy...
unsubscribed....
unsubscribed....
#42
Sharkwerks seems to flash at the same time as these mods...see post #4 in this very thread. Is it because their clients want even MORE power or because the bolt-on's w/o a tune don't net much of a power increase without one? I know what my guess is and I already know your opinion but maybe they can chime in.
https://www.6speedonline.com/forums/...ml#post2648719
When I bought my 997.1TT it already had the EVT580 tune (100hp over stock) and the smaller IPD plenum. I decided to bump up to the EVT700 package and my shop, who definitely knows their ****, said that this plenum was adequate for that power level. On Evoms site, their power package doesn't even recommend replacing the stock plenum (upgrading to both the IPD Comp Plenum and GT3 TB) until their EVT720 tune. I changed to the Comp Plenum and GT3 TB anyway since I had the motor built and bumped to a 3.8L and wanted everything in place b/f going any higher in power. My point is, the plenum on the 996/997 is supposed to be horribly inadequate whereas the Cayenne plenum is supposed to actually be pretty good. If EVOMS doesn't even recommend replacing the plenum on the 997.1TT until they're 220hp over stock (and actually the only bolt-on added from the 700hp kit) then what could one deduce about the effectiveness of the plenum on the CTT?
Anyway, I actually WANT you to be correct...all the personal attacks aside. I just don't believe you are b/c there is currently no proof that I've seen (no dyno available on IPD's own website??) or just seat-of-the-pants testimony. Throttle response, I believe. Smoother acceleration...um, ok. But the power gains their website states for the CTT are, as yet, unproven. I already have cat bypass pipes and BMC filters. If I can net a total of 60whp just by adding the final IPD plenum while keeping the ECU stock then that would be great. I'll eat my shoe if you produce the dyno showing 60whp (or ~78.91 crank hp using your 23.97% AWD drivetrain loss).
#44
How could I take something personal on a forum from a person I don't even know? You don't know as much as you think you do.
This is your opinion and you're entitled to it, I respect this.
Given a 23.97% AWD drivetrain loss, if a part makes 30 HP at the wheels, you would add 30 + 23.97% to determine estimated flywheel HP, so you would be making 37.1 HP at the crank. 23.97% is estimated and will vary from car to car and generation to generation. I rendered that number from the Fabspeed Dynopack tests as an example.
What I saying is that in the case of the filters, plenum, and CBPs, the effective WHP was similar to what would actually be rendered at the flywheel:
The Fabspeed dynopack run for the car under test was 363.5 HP. If you add a 23.97% AWD drivetrain loss, you get 450.631 HP. That's where the 23.97% number comes from. The car appears stock to me and on par with typical AWD drivetrain loss percentages, so I conclude the car was indeed stock for the run.
The dyno sheet claims with filters (assuming BMC, but it doesn't matter)and CBPs, their car under test rendered 26.8 WHP to bump WHP to 390.3 from 363.5. So once again, 390.3 + 23.97% is 483.55 at the crank.
Now, if you read further, you would see that I made an assumption for the IPD plenum. I took into account dyno differences, test method differences, atmospheric differences, etc, etc, I simply said we would assume the IPD plenum made 30 WHP on this run and car under test.
So, this would mean, 390.3 + 30 = 420.3. Now, again, 420.3 + 23.97% is 521.046 HP at the crank. So fully stating this was completely hypothetical, I said to take off 15 HP from the top of the crank number (521) and you get about 506 HP at the crank.
So, with the wheel HP gain with the assumptions was 56.8 HP over stock (363.5 + 56.8 = 420.3 WHP). When you look at the crank HP, at 521 HP, this would be a whopping 71 HP over stock which I certainly don't believe is accurate.
Herein lies your problem with the statement I made, 71 HP at the crank and 56.8 WHP are VERY different. However, since I was using hypothesis, I subtracted 15 HP from 71 and rendered 56 HP to the crank as well.
I absolutely violently agree that the actual WHP and crank HP would not be the same. I just wanted you to see where I got that from.
Bottom line, if you run too lean too long and you get your EGTs up to high, I don't care how much coolant you pour into the head(s), YOU WILL melt the heads at some point, even on a Porsche.
From the IPD website (and trust me, they are 100% correct about this):
"Aluminum has a relatively low thermal mass. It's capable of heating up quickly but because of its molecular packing configuration it's not capable of storing much energy. While theoretically it does have a higher thermal mass than plastic, the resulting change in inlet air temperature is minimal."
AND
The colder the air traveling through the intake system the higher the increase in horsepower. Cooler air is "denser" air, because cooler charged air carries more potential energy. This increase in energy allows for greater combustion within a given volume, ultimately yielding more power and efficiency."
They are dead on about this, it's been proven over and over again.
He just got PWN'd, that's all.
No one said you had to watch this channel.
#45
What I'm trying to get you to understand is that after intake, plenum, CBP, full CB exhaust, diverter valves + ECU Flash, you have a car pushing closer to 560-570 HP at the crank than 520-530 HP and most of the tuners will tell you this.
Most of the CTT mods are additive, not entirely because of restrictions like smaller TB and intake manifold, intercoolers that can no longer cool the charge air, etc, etc.
We all know Dyno testing is a surprise. I have yet to be surprised everytime I get some time on the Dyno. I'm just saying (and I believe I'm right about this with conviction) I'm over 500 HP at the crank with those mods. I could be wrong and I will be the first to post here if I am, but I really don't think I am. The CTT is really surprising me.
You said earlier that you only had the TechArt exhaust.
Remember that number is based on the car under test from the Fabspeed dyno run. I will honestly say, I won't doub't you'll be over 60 HP at the crank.
