Anyone notice higher gas mileage with a K&N air filter?
Hi Pepper
I am on the fence, but if I was doing it I would use BMC over K&N.
Benefits
May give you 2 or 3 HP over the stock paper filters.
May give you an extra 1 or 2 MPG over stock.
You will never have to buy another filter ever again.
May give the engine a more aggressive sound at W.O.T.
Disadvantages
May let more dirt into the engine, shortening its life.
May contaminate the Mass Airflow sensors over time.
Benefits
Disadvantages
Hi Pepper
Benefits
May give you 2 or 3 HP over the stock paper filters. - doubtful even if you won't notice a difference
May give you an extra 1 or 2 MPG over stock. - saw no gains with the bmc, only less gas mileage
You will never have to buy another filter ever again. - the only true benefit of a drop in
May give the engine a more aggressive sound at W.O.T. - no sound change whatsoever
Disadvantages
May contaminate the Mass Airflow sensors over time. - it's a filter, it will filter out the same as the oem filter
Benefits
Disadvantages
Thats true pct, but I was thinking more about the possibility of oil contamination from the pre oiled filter.
This may or may not be a problem, but I thought it should be mentioned.
:thumbsup:
No thanks.
tropicatango
12-04-2015 02:45 PM
