Porsche Badge
Porsche Badge
I purchased the new Panamera "PORSCHE" badge from a dealer several weeks ago, but I haven't attempted to put it on yet. It was easy enough to take off the old Cayenne badge, but is there anything I should know about putting the new one on? Obviously I am going to wash it first, but the badge comes attached to a thin piece of papar and doesn't feel all that sticky. Is it necessary to add any adhesive or will it adhere as is. Other questions are: Should I wax the back hatch first, should it be applied in a warm garage, should I warm up the letters with a blow dryer etc...? I don't want to screw it up so any help would be appreciated.
Actually you want to remove any wax before you stick the logo on; just a gentle wipe with rubbing alcohol or wax remover will do the trick. Then, as noted above, just peel and stick. Do it right the first time though because you only get one shot. I used painter's tape to help me align and center my logo when I replaced mine.
Lastly, measure distance and mark measurements using blue painters tape. It may not seem sticky now, but once you pull the tape away, the adhesive on the decal is very very sticky.
joseph_number1
07-19-2018 05:45 PM
