Anyone find a great aftermarket battery for Cayenne S
Old 04-20-2010, 06:36 PM
Pepper's Avatar
Pepper is infamous around these parts
something that will give at least 900 CCA
Old 04-30-2010, 02:23 PM
rriva's Avatar
rriva is infamous around these parts
Would the Optima not work? What problems have you had with the battery?
Old 04-30-2010, 04:50 PM
Pepper's Avatar
I would LOVE the Optima battery, but there does not seem to be a match...
I need a battery, I don't want to pay $300.00 at my local dealer. Suncoast has it for $170.00 which is fine but they will not ship. I tried AutoZone and the replacement battery they have is not enouph CCA of 760, we need at least 850, 900CCA would be GREAT, I'm getting worn out looking.
If you don't have the correct CCA, my car needs the key turned back and forth every 6th or 10th start and it's anoying. I know this cause I tried the autzone 760 cca and does the same thing my 7 year old battery does. All electrical checks out fine, just need a battery not from the stealership.
Old 04-30-2010, 09:46 PM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
Just out of curiosity, what's the OEM factory battery spec?
Old 05-01-2010, 07:17 AM
Pepper's Avatar
Cayenne Battery
It calls for a #49 and is 850 CCA, sealed and vented.
Old 05-03-2010, 03:13 PM
medtech's Avatar
medtech is infamous around these parts
The only thing wrong with the Optima is the physical size of the battery.
Since the battery fits under the driver's seat, there are limitations.
I personally have not opened it up, but I plan to one of these days, to see if there is ANY way I can squeeze an optima in there. I had the Red top in my 996 and liked it a lot (that took some customizing as well, but the work space was bigger.
If anyone has pics of the OEM battery in the compartment, or even better would be exact measurements, I would love to see them.
Currently I'm moving, so I don't think I'll get to this project anytime soon.
Old 05-06-2010, 07:58 PM
blrx7r1's Avatar
blrx7r1 is infamous around these parts
I bought my replacement through my local BatteriesPlus. It is a Werker brand which in just checking their website, doesn't look like they carry anymore. The new one that fits is a Rayovac SLI93T8 800CCA model. Not what you were looking for exactly but it might work?
Old 05-10-2010, 02:16 PM
medtech's Avatar
Wow, Thanks Jim!
This may just be the motivation I need to get under the seat and measure the OEM opening.
Old 05-10-2010, 03:55 PM
pcst's Avatar
Here is the spec of the Touareg battery size, according to the aftermarket replacement battery for Touareg;
9 in. x 5.43 in. x 9.13 in (This could be wrong size, keep on reading below, you will get more accurate #s)
I wonder if Cayenne battery is the same size as above.
Old 05-10-2010, 04:33 PM
medtech's Avatar
Here is the spec of the Toureg battery size;
It's probably a good bet that they are the same.
Can you clarify which is height, width, etc.?
A quick look at the Red Top shows that it's not even close.
The real question is how much space is down there, and what's in the way? Can it be modified?
Old 05-10-2010, 04:56 PM
pcst's Avatar
Take a look these sites, bunch of picture;
http://web.me.com/airtahoe/Touareg/Battery.html
http://www.precisionframe.com/Touareg/batteryfront.php
Hmmmm,,, after looking at the actual battery pictures, it doesn't look like the dimension I provided above doesn't look correct.
Here is what the real VW Touareg owner says; 7" wide x 7.5" tall x 15.5" long
Old 05-10-2010, 05:14 PM
pcst's Avatar
Interstate Battery aftermarket battery for 2006 Cayenne V8;
http://www.interstatebatteries.com/c...nths+-+720+CCA
Product ID: MTP-H8
Short Description: Interstate - 85 Months - 720 CCA
Amps: 900
Cranking Amps: 900
Cold Cranking Amps: 720
Voltage: 12
Termination: A
Pro-rata Warranty: 85
Weight: 53.6
Width: 6.89
Length: 13.94
Height: 7.48
Old 05-11-2010, 04:34 PM
medtech's Avatar
Ok, if those numbers are correct, this is looking somewhat promising. The pics show some wiggle room in the width, so that's good there. There's plenty of length, so no probs there. The only issue is the height.
Only the Red Top 78 will meet the height requirement, but the terminals are on the side.
It's possible the OEM cables might fit, but most likely they will need to be modified (Porsche generally doesn't leave any slack).
Old 05-11-2010, 05:04 PM
OCNYPORSCHE's Avatar
OCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura about
I bought mine from Walmart. It was a little smaller, but it working great.
Old 05-11-2010, 07:46 PM
medtech's Avatar
Yes, walmart may be the smart choice.
To the OP, your best bet is to get the $200 toureg battery and install it yourself.
I may follow this project through to completion, but in the end I will spend a lot of time, and probably more money to put the optima in (after mods). It will still need to be vented per the above post. The only advantage will be saving a few pounds, and it's truly maint free.
Quick Reply: Anyone find a great aftermarket battery for Cayenne S
