Cayenne GTS Lowering
#40
We provide detailed instructions for the installation, so if you have any experience with simple wiring, you can certainly install it yourself.
On the 955 platform, you can go about 55mm lower then your existing ride height, and on the 957, we recommend about 45mm lower.
The best part about our unit is that with the flip of a switch it can be bypassed, restoring your factory ride height settings. So if it's snowing a lot, simply switch it off, and you'll have full terrain mode back if you need it.
There is some wiring involved, but as I said, we provide good instructions with the kit. Most people will have a dealer do the install, but if you have any experience with wiring (stereos, amplifiers, etc) then you can probably do it.
#42
We would be happy to ship internationally. The installation is very straight forward and the system comes with step-by-step, easy to follow instructions.
#45
Guys....we currently have the lowering control unit on sale here:
http://www.championmotorsport.com/pr...cmslcu955t.htm
