06' turbo diverter valve vacuum line problem please help
Old 07-16-2010 | 07:15 PM
trouble29's Avatar
trouble29 is infamous around these parts
I have recently purchased a 06' turbo. I am having putting it together and cant figure out where the vacuum line from the right side diverter valve connects too. Its a solid plastic type long hose that i ordered from the dealer but do cant figure out where it goes after it connects from the diverter valve. It doesnt show on the dealer diagram. Please help.
Thanks.
Old 07-16-2010 | 09:17 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
The hoses connecting directly to the Diverter valves are rubber hoses. They connect to a tee-fitting somewhere in the front of the motor. This is the only pic I can find of the line (#34).
Old 07-17-2010 | 10:00 AM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Yep, it is a rubber hose from each diverter valve that runs underneath the main upper boost lines and goes to a T fitting under the Y-pipe (part #8) that is attached to the throttle body. If you remove the Y pipe you will see the T fitting for the diverters.
Old 07-17-2010 | 02:53 PM
trouble29's Avatar
thanks for the help guys i will check it monday and hopefully it all goes together.
08-21-2015 06:34 AM
Lucid Moment
08-20-2015 02:22 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
Quick Reply: 06' turbo diverter valve vacuum line problem please help
