TireRack introduces the AT Italia Presa in Black!
Originally posted by CayenneS
He never said that they are the same wheels as the Gemballa. Instead, if I remember correctly-- he thinks after thorough research that they are made at the same foundry as the Gemballa wheels (made by speedline), so they are pretty similar... I highly reccomend that you refer back to the thread below this one that has like 85 responses or whatever and over 1000 views on this same matter
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
Originally posted by DEETZ
Damon: what does it mean by 2 year finish warranty? If we get rocks or chips, do they repair it for free?
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
Originally posted by Itzkirb
Buy these and just put the Gemballa Center caps on. No one will know.
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
Damon: if the Gemballa cap can be fitted into the AT Italia wheels, can you let me know? I want to get one more set of 22", its so cheap!
I believe Jamy has his Gemballa wheels shipped already! hint hint :P
Ok Guys, here are the pics.....
The center-bore of the wheel is approx 73mm (20" wheel tested) and is smooth all the way through to the centering ring groove. See pics. Assuming the Gembella cap is 72mm wide, getting it to stay in may take some re-engineering on your behalf..
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
The centerbore. If you look at the area that would be the outer edge of our centercap, it is machined at more of a right angle so that the AT Italia cap sits fush in the wheel. The Gemball is more rounded, so there is definitely some finish machining that is different between the two. And there is no getting around the ATI cap scuffing the paint as you see.
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
Here is the Gemball for comparison....
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
285/30 22 is the widest we list. Can anybody with experience with the 295 answer this?
Anybody..............
Anybody...............
Bueller?.................
Bueller?...................
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
