275/40/20 vs 295/40/20
I found a fantastic deal on a set of Pirelli Scorpion Snow and Ice tires, but they are 295/40/20.
I was about to mount a set of 275/40/20.
The way I understand it, is the 295, is the width of the tire, so larger contact patch (and for snow, not ideal). But the 40 profile will give me a bit more height in the sidewall which wouldnt be bad for snow.
Am I nuts to consider the 295s?
275/40R20
Load Index 106 = 2094lbs (950kg) per tire
Speed Rating “V” = 149mph (240kph) 106V XL N0 (Porsche) Not required for
this tire.None 2094 lbs.
50 psi
13/32"
36lbs. 9-11" Recommended rim width
9.5" Measured rim width
11.2" Section width
NA Tread Width
28.8" Overall Diameter
295/40R20
Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “V” = 149mph (240kph) 110V XL Not required for
this tire.None 2337 lbs.
50 psi
11/32"
37lbs. 10-11.5" Recommended rim width
10.5" Measured rim width
11.6" Section width
10.6" Tread Width
29.3" Overall Diameter
Doesn't look like much of a difference but it would be significant, depending on your snowfall etc. It's always better to have a narrower tire IMO but If the price is that good and you think this won't be an issue than I would say go for it.
50 psi
13/32"
11.2" Section width
NA Tread Width
295/40R20
50 psi
11/32"
11.6" Section width
10.6" Tread Width
