Upgrading to Turbo S Intercoolers
Old 12-12-2010 | 08:25 PM
PianoProdigy's Avatar
PianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud of
I sent an e-mail to Suncoast asking what parts I needed to upgrade my CTT with the Turbo S intercoolers. This is what he sent me. Does this look complete?
1 955-110-803-41 INTERCOOLER 1 1075.07 1075.07
2 955-110-804-41 INTERCOOLER 1 1075.07 1075.07
3 955-110-838-00 PRESSURE HOSE 1 67.42 67.42
4 955-110-368-00 PRESSURE PIPE 1 93.07 93.07
5 955-110-807-00 HOSE CLAMP 2 20.95 41.90
6 N-106-203-01 O-RING 2 4.73 9.46
7 955-110-837-00 PRESSURE HOSE 1 61.38 61.38
8 955-110-367-00 PRESSURE PIPE 1 93.07 93.07
Old 12-12-2010 | 09:01 PM
pakundo's Avatar
pakundo is infamous around these parts
if i may ask...why change to turbo S intercooler...have you maxed out the original intercooler?? and at what boost?...just asking...
Old 12-12-2010 | 09:21 PM
snzuloz's Avatar
snzuloz is infamous around these parts
How much does the above list cost?
Old 12-12-2010 | 09:26 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
looks like the last numbers in each row are the prices for each item.
Old 12-12-2010 | 09:29 PM
snzuloz's Avatar
I think your right now that I look at it closer (oops must be losing my mind!) pretty pricey for a couple of small air to air units...
Old 12-13-2010 | 06:54 AM
Yes, but to fabricate something that is really nice would probably cost a lot more.
Old 12-13-2010 | 06:57 AM
From my research, it appears that the factory tune and intercoolers are the only additional power-makers in the CTTS over the CTT. My plan is to swap to the S intercoolers and then send my ECU back to Sharkwerks for their ECT600 program (meant for the Turbo S). For all intents and purposes (at least with regard to power makers), once the above is completed, I will have a full bolt-on Turbo S and should be able to make the power quoted here:
Old 12-13-2010 | 08:21 AM
Markenstein3D's Avatar
Markenstein3D is infamous around these parts
i know you are looking for just the additional power.. quick question on this project, is it necessary to add the bigger breaks too? or does the OEM brakes for the TT enough?
Old 12-13-2010 | 08:25 AM
Obviously depends on your goals. For me, the current brakes are more than sufficient.
Old 12-13-2010 | 11:18 AM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
I think it's a good upgrade. The stock ones heat soak quickly. I'm going to take a different route, though, by going with a meth injection system at some point. I was also looking at putting a larger, single core up front since there is room for one, but I figure the meth injection would be less expensive.
Old 12-13-2010 | 07:06 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Cool
I think it will cost you almost half as much to have larger custom units made.
I had a custom set of dual intercoolers made for my twin turbo Audi S4 and it was far cheaper than the list price on these factory Turbo S units.
I someone had the physical specs of the Turbo S units it would be even easier.
Old 12-13-2010 | 10:11 PM
PutterMcGavin's Avatar
PutterMcGavin is infamous around these parts
Just throwing this out there as an idea but I have NO idea if it will work but...
The 08+'s are rated at 500hp or so stock but do they use newer intercoolers at all? Possibly something similar to the ones in the 955 Turbo S's? HP is very similar and I assume air flow capacity must be too. Since the 957 is essentialy a reskinned 955 maybe they could be used if they're larger?
Again I have NO idea if they are any different/better but it might be another angle to approach...
Old 12-14-2010 | 08:43 AM
Look like there are a few more parts needed per this document taken from https://docq.com/app/pres/d3b9ebb54b...6ad83a31ea1bf:
Old 12-14-2010 | 10:06 AM
LCatGA's Avatar
LCatGA is a splendid one to beholdLCatGA is a splendid one to beholdLCatGA is a splendid one to beholdLCatGA is a splendid one to beholdLCatGA is a splendid one to beholdLCatGA is a splendid one to beholdLCatGA is a splendid one to behold
It should work well - somebody done it before
Old 12-15-2010 | 03:57 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Whats the cost for all the parts app.? Probably a lot cheaper to do a meth kit.
Would be nice if they made aftermarket coolers for the Cayenne!
