Stole the Wifes Cayenne, Going Under the Knife
#46
I have a 2010 V6 so the bumper is a little different. For install, do I need to remove the bumper and cut the wire?
TIA.
#47
Said I was going to sell my Evoms and give these a go. I am doing some other custom work and these will give me a tad more clearance. If anyone is interested in my Evoms intakes CHEAP, here you go: https://www.6speedonline.com/forums/...ml#post3092615
Vivid is nice enough to do a little extra customizing for me, but for now I will keep the details a surprise
#50
Not only that but I mean, alunimum is gonna last.........and you could probably put some sweet color on it easily.
#51
Going back to our intake... We dont take anything away from any other product, we simply produced an option. Agency Power has developed many different intakes for different vehicles as seen here - http://www.vividracing.com/catalog/a...intake&x=0&y=0
Although we have these for sale in textured black powdercoat, we do have raw aluminum kits read in which we can powdercoat the intake tubes ANY COLOR you want for an extra $50 cost.
#52
Can you pm how "simple" this is....I do a lot of things on my own....but I find I usually break things the first time into it before learning and adapting proper techniques.
Also.......if mine is a 6er.....could I replace just the right side(when facing the engine) with your aluminum? It looks like yours has much more airflow than the anemic stock plastic stuff....
#53
The only thing we dont show in the pics above is the wiring. It comes with a wire loom. You just need a ground, power, and switch. We extended the wire for the switch power through the firewall and then tapped into the fuse box. Its mainly a time thing.
I have no idea if the intake will fit the V6 on that side.
#59
I swear Vivid can just sell the first piece as a replacement on the V6 too.....can you get someone nearby to dump a 3.2 and 3.6 on yourdoorstep to look and do a quick assessment.
I would love a more masculine sounding intake......you can hear a deep sucking sound when it activates already with the choking factory airbox in place.
heres some quick shots.......check out the Twin turbo V6 Touareg
