"whining" sound when car is rolling..
#32
not sure if anyone has posted this but check your power steering fluid. mine was making the noise and it went away after i topped up. dealer was giving me the stories i read about in the first page as well.
#33
My 09 GTS started making this noise a few weeks ago. At first I thought it was a pebble that got stuck in the rear brake pad but the noise won't go away. I only hear it going 1-5mph with my foot off the brake. Soon as I depress the brake pedal, the noise is gone.
#34
Ur sure this is a whining, not a squeal, creak or scraping sound?
Does the sound change if u put the car into Neutral?
#36
The parking brake on these things are prone to sticking. Try engaging it fully, and popping it back out a few times
#38
Hey folks. I have a 2005 CTT with 80000 miles and have had the dreaded whining issue as well. I just had my cardan shaft replaced, and it seems as though the issue is better, but the whine is still there from time to time. It has only ever occurred when accelerating, mainly from a stand still. You can hear a whine/moan and a faint vibration in the steering wheel... ideas if it isn't the cardan shaft? Could it be the tranny or front diff is going bad? Thanks!
#39
Hey I got the same issue "whining noise", 1-5 mph, while breaking or accelerating slowly, usually when car is cold, on my 2006 Cayenne Turbo. This is random and doesn't happen all the time. I can tell it's not the wheel bearing by driving the car in circles left and right on a parking lot and it is not a grinding noise but a whining noise. I'll try to record it today and see if it happens. Someone has to know what this is, I know couple of members posted that this is normal, but I disagree, and I hope it's something stupid and not the transmission. Oh ya it sounds like this "whe whe whe whee wheee" and stops when I come to a complete stop :/.
#40
I haven`t had any further issues while breaking but the whining is annoying and I still get the faint vibration in the steering wheel at the same time whilst accelerating. Not sure what else to do...
#42
If I was savvy enough I would do the same... If you happen to figure anything out let me know will ya? Only think I can think of is the tranny, the front diff or the transfer case. Not sure which one is more likely to cause vibration in the steering wheel though
#43
As promised here is the video trying to diagnose this POS. I hope we are talking about the same thing.
if you have or had the same issue post here what it was. In the mean time I will try to do my own diagnosis. I also started hearing some ticking noise in the rear... at 1:34 tick tick tick, sounds like a relay, or cd changer? clear sound of wining at 2:50.
#44
#45
my 06 ctts whines as well, 83k miles. sounds to me like the transmission though the ps pump could be a possibility as well. same as another post, i really only hear it when the window/s are down. definitely not brake related in my case and the cardan shaft would be highly unlikely imo.
