2004 Cayenne S Air and Pollen filters.
I own a 2004 Cayenne S and I need to change the Air and Pollen Filters.
Are they easy to replace? Any help on how to replace them would be greatly appreciated.
TGM
TGM
TGM,
I know they arent expensive, you can get them off of suncoast porsche parts online or at autozone. I'd reccomend the K&N air filters as they are high flow and these V8's SUCK the air down basically all begging for their own turbo.
Ill check the ALL-DATA and see if the pollen filter has intructions for install. The air filters are on the left and right sides of the motor torwards the front of the engine compartment. just pop off the paneling near them and you cane get the cases open just enough to slide the filters up and out.
do check to make sure they are dirty. I checked mine the other day on my 06 and they were super clean even after a couple years, of course the ohio air isnt quite to dusty compared to the southwest.
also i noticed you said you have an 04 S, have you had the coolant pipes done? its important to get on these as letting them fail can run you serious dollars on the starter or even worse, trans seals.
I'm on a trip to see a client this weekend, but I will check ALL DATA on sunday about the pollen filter.
cheers mate,
Lance
cheers mate,
Lance
cabin filiter is located under the glovebox. Remove the plastic cover with I believe a T10 and you'll see an air box in there. The box opens up and the filter slides right out. You'll see what I'm talking about in there.
Also while in there i recommend blowing air to clear out the hvac condenstate drain too
04-28-2022 12:38 AM
away
09-04-2015 12:30 PM
pshep138
09-01-2015 09:45 AM
PelicanParts.com
08-26-2015 04:25 PM
