Vibration in 2nd at 2000RPM only...
I am getting a little bit of a vibration coming from the midsection of the car (under acceleration) at 2k rpm in 2nd and 3k rpm in first. no other gears.
i recently replaced the drive shaft but did not have this problem for the first couple months with the new shaft. is it possible a balancing weight fell off?
when the first shaft went, I only got vibration at high rpms not low.
thoughts?
thoughts?
Anything is possible I guess - but I haven't seen balancing weights on any modern driveshaft. They usually auto-balance them by adding some weld material where weight is needed. Was this a new or rebuilt shaft? In any case - it should be under warranty from whoever the source for the shaft is..
miken168
10-06-2015 09:21 AM
