Cruise Control doesn't work
Old 12-20-2011, 03:04 PM
Anne123's Avatar
Anne123 is infamous around these parts
Hi guys! Just got my 04 Cayenne with 81K miles last month. Drive mostly in town so hadn't had the chance to try out my cruise control until last week. I discovered it doesn't work. The light comes on like it should work, but it doesn't. I tried the search feature on here and saw someone mention that can be a symptom of a problem with the brake switch, but not much more info than that.
Anyone have any experience with this? What am I looking at?
Old 12-20-2011, 03:19 PM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
Did you check the fuses?
Old 12-20-2011, 06:30 PM
Anne123's Avatar
Not yet. I looked up the fuses in the owner's manual, and I don't see one labeled 'cruise control' specifically, so I'll probably have to pull them each out and check them. Maybe I'll be able to do that after the kids go to bed.
Old 12-21-2011, 08:05 AM
GTS Jay's Avatar
Sounds like a good place to start. Let us know how you make out and if that didn't work perhaps one of the more technically knowledgeable folks will have a better path for you to take.
Old 12-23-2011, 08:52 PM
smokersteve's Avatar
smokersteve is infamous around these parts
Mine also stopped working. Let us know what you guys find out!
Old 01-11-2012, 05:58 PM
chipu12's Avatar
chipu12 is infamous around these parts
mine was easy diy 24$ fix
On MY04 it was the brake light switch located on the brake pedal mount.
Old 03-06-2012, 02:56 PM
bump bump
Old 03-06-2012, 06:54 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
This. Does it start without putting your foot on the brake pedal?
Old 05-05-2012, 04:38 PM
bump bump
Old 09-29-2013, 09:05 AM
ChrisGUGA's Avatar
ChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to beholdChrisGUGA is a splendid one to behold
Mine does start with my foot off of the brake and my cruise also doesn't work. Any suggestions?
Old 09-30-2013, 11:48 AM
linksamui's Avatar
linksamui is infamous around these parts
I do wonder how to operate that too. The light been on on the dash but I don't know how to get it to work either. Was cruising on the highway the other day and tried to turned it on. Didn't work either. 04 CT.
Old 10-04-2013, 06:23 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
I have the same thing in my 05 CTT. Does anyone know the fuse number. I cant find it in the manual either.
AA
Old 03-09-2014, 11:25 PM
ChrisGUGA's Avatar
bump
Old 04-07-2014, 09:43 PM
LiketheMonth's Avatar
LiketheMonth is infamous around these parts
Highly doubt it's a fuse. I would definitely check the brake switch on the back of the brake pedal. Installing a new one can be a PITA. I filed the plastic tabs just slightly to help twist them in. Good luck.
Old 05-13-2014, 10:04 PM
sofla1's Avatar
sofla1 is infamous around these parts
'06 Cayman S Cruise Control solution
My '06 Cayman S cruise control refused to work.
Simple solution, weird but worked, disconected the battery & reconnected it and all was good !
Has happened twice, once 6 years ago & again last week !
Quick Reply: Cruise Control doesn't work
