NEED brake pads / vented rotor for 08 CTT. Pls help!
Hi All,
My brake start making sharp noise from last night. I checked all four corners, pads are nearly worn out.
2008 CTT use special (I'd rather say strange) rotor setting. 368mm front, 358mm rear is a really usual size. I've been looking for the correct pads, as well as the vented rotor since last week from many resources, but with no luck.
Can anyone point me out the correct place to grab a set?
Is the turbo brake line made of stainless steel or rubber? if it uses rubber, where can I get the stainless one?
Motul RBF600 Brake Fluid is ready in my garage.
Feelgood MD
03-24-2016 10:35 AM
ECS Tuning - VW
09-02-2015 10:03 AM
