CTT Throttle Body Upgrade?!
Hi, I have a 08 CTT and Im planning to upgrade to the TS throttle body. Besides getting the plenum (I already have the 76mm One) is this a Plug/play?
Anyone made the upgrade already? thanks
what is the size difference of the TB's? Are the manifold part numbers the same b/w the two models?? If they are the same it might just bolt on, but then there is wiring...should be the same though. Then what about your tune? You might need to get tuned again.
I don't suppose you have an air fuel gauge in your cayenne? What about dyno sheet with afr? Almost 500 whp! NICE! Assuming some drive-train loss of ~25%, maybe 600hp at the motor.
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
turbotuner20v
09-11-2015 12:02 PM
LiquidElephant
08-27-2015 06:17 PM
