Staggered Tire sizes for 22" wheels
Old 02-22-2012 | 11:55 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
OK, so the wheels have been chosen.
22x9.5 front
22.10.5 rear
the tire sizes I'm looking at right now are 265/35r22 and 295/30r22
Does that sound right?
Using a tire/rim size calculator, the tire diameter will be 29.3" in the front and 29" tall in the rear.
I would like to run a taller tire, especially in the rear to mitigate wheel damage from any potholes and junk. Could I get away with 265/40r22 and 295/35r22?
Thanks guys!
Old 09-14-2014 | 08:27 PM
sempaipaul's Avatar
sempaipaul is infamous around these parts
Reviving this topic…
What do you guys think? I am facing the identical question right now…
Old 09-15-2014 | 12:02 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
You can run up to a 30" diameter tire with any clearance issues. I think I am running a 30.2" tire on both my summer and winter setup.
Old 09-15-2014 | 05:48 PM
CALMOTION's Avatar
CALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really nice
30.2
What size of tire is that :-). That must fill the wheel well very well. I see BMW use 315
Old 09-15-2014 | 06:33 PM
Moderator
305/35/22 all the way around. Technically speaking, I mispoke; it is 30.4" in diameter
Yes, that is one reason I use them is to fill the tire gap when lowered using the Techart Lowering Module. The other reason is the added sidewall height make for a smoother ride and absorbs/protects against potholes much better.
When parked, at the right angles, it looks questionably stanced.
As an example, here are a couple of pics of my winter wheel setup 30.04" in diameter; just a hair shorter. Also, these are the most narrow 20" diameter wheels I could find since narrow is better in the slippery conditions.
I see BMW use 315
I think you mean they run 315 in rear only; they could not run this in the front on 22s. As I already mentioned, I run these 305 all the way around so I can still rotate the tires. If you wanted, you could put 325/335 in the rear; you just cant rotate the tires anymore.
Old 09-16-2014 | 10:55 AM
CALMOTION's Avatar
Non snow
Do you have pictures of non snow tires from the side and rear with the 305 on..Thanks
Old 09-19-2014 | 01:12 AM
Moderator
Sorry, not off hand that I can think off.. but here are two other members running the same tire size and posted pics in past threads:
https://www.6speedonline.com/forums/...ml#post3254628
https://www.6speedonline.com/forums/...ml#post2959283
Old 09-19-2014 | 12:24 PM
CALMOTION's Avatar
20"
On the stock 20 I think they are made by 808 I saw BMW are also running 20 with 305/35/20 would they fit the 20 inch rims? Thanks again for your response.
Old 09-19-2014 | 04:41 PM
aspenone's Avatar
aspenone is infamous around these partsaspenone is infamous around these parts
Those winter wheels look awesome
Old 09-19-2014 | 05:13 PM
HOiYA's Avatar
HOiYA is infamous around these parts
RM,
What 305/35/22 summer tires are you running?
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
08-19-2015 06:35 PM
Wheel Experts
American Muscle
08-19-2015 09:07 AM
Wheel Experts
Wheels/Tires
08-19-2015 09:05 AM
Quick Reply: Staggered Tire sizes for 22" wheels
