Jacking up the Cayenne (w/ air suspension)
I tried searching the forum but couldn't find the exact needed information on how to use an aligator jack to raise the Cayenne without destroying the air suspension.
I have a nail in my rear left tire and i need to remove it so ghat i can take it to the tire shop for a plug and paych work.
Any of you guys have tried jacking up your Cayennes? Where are the jack points if i were to use an alligator floor jack? And what do i need to do prior to jacking it up? Push what and which buttons?
Any info or an experience shared would be apreciated. TIA!
Lock the air suspension, the instructions to do so is in the manual. Press up on the level change selector for 10 secs. The instrument cluster will says "regulation off" once done.
Then jack up the vehicle on either the circle lift supports (if you have an adapter for it) or under the side rockers using the factory jack. There are little doors on the rockers that remove in order to use the factory jack.
circle left support
Link to eBay Auction
If you are referring to one of the main subframe mounts, it is not recommended. However, since they bolt right to the most rigid part of the chassis, I have used them in the past to lift the vehicle up with proper protection to the rubber bushing. You can use a solid rubber hockey puck as a buffer between the metal jack pad and the subframe bolt/mount. Once again this is not the recommended method.
Thank you very much mr Renaissance.Man! Appreciate this very much. I dont think we have those adapters but i can try and have someone attempt to copy or fabricate something similar. I will also try to find the post where that stud goes in.
Thank you for the pictures as well!
For Jacking info see this for additional info:
http://www.pelicanparts.com//techart...ur_Cayenne.htm
I had to once in '07 or '08 with my last one. It's all clearly laid out in the manuals. The German engineer's put it in step by step layout so it would be good to read that first. Once you do that it's really easy.
lovethesport
Cayenne 955/957
07-11-2010 08:37 AM
2012, air, cayane, cayenne, floor, instructions, jack, jacking, locking, pl, point, porsche, regulation, suspansion, suspension, turbo
