My new wheels/Tires are on!!! And I should be happy, but wait!>>>
You're Setup looks great! You have lowering links for your ride because you have the air suspension correct? I have the base v6 and was thinking about lowering it, but id have to get springs. Do you know about how much yours is lowered?
Also what are your wheel specs? 22 x ? width? Tires sizes?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!!
Yea I used links to lower it...I'd say it is lowered about 1.75-2.00" all around. I should have measured before and after but I didn't. I was thinking of lowering a little bit more, but a buddy said it looked pretty good the way it is. That's on the "low" setting, just under the normal setting. I drive it at that level and it feels great.
My setup is staggered.
22x10.5 rear with 295/30
22x9.5 front with 265/35
Thanks for the info! That's interesting, because there is another thread on there with a 955 on 22" Ruger Meshs as well. Its also staggered with 9.5 and 10.5 but does not look as aggressive as yours. Your rears look like they push out further. I wonder if you have more aggressive offsets. It has +50 + 45. Are you running spacers or anything?
https://www.6speedonline.com/forums/...rinstripe.html
^^^ LOL yea I noticed that too!! Mine does look a little more aggressive from similar angles, but I'm not sure why as the sizes/offsets of the wheels and tires are the same. I'm not running any spacers either.
It might just be the color and the contrast that it has with the wheels. Maybe the pin stripe as well?? I'll take some more pics and put them on forums here pretty soon for comparison. Either way I'm digging the way it looks.
