I f****ed up bad...
I f****ed up bad...
In haste, I poured about 2 oz of brake fluid into the power steering reservoir. My first reaction was to syphon the fluid out of the reservoir (which I did) then I realized that the the brake fluid is more dense then the PS fluid and has probably already sank down into my ps pump. What should I do? Am I looking at replacing my whole steering rack, pump and hoses
Suck out as much as u can. If the fluid was extracted pretty quickly, i doubt it went into the ps system. You can also drain the ps fluid at the rack from under the car. Pour in some ps fluid to flush it. No need to change any hardware.
I emptied the reservoir as soon as I noticed it, but I'm still nervous because the brake fluid is a lot more dense then the pentosin and probably sunk right into the ps pump.
I have not turned the car on yet or moved the steering wheel.
I bought a few liters of pentosin ($$$$ lol) to try to flush out as much ad I can.
I just dnt know how far into the system the brake fluid is
They have the right idea. Just drain as much as you can, fill and flush again. Then you should be good to go when you fill again. They stated worst case. No need to replace until it happens (if at all). Good luck. Did something similar with an old car once (not much but some brake fluid into PS container - wife was distracting me too lol). Drained it and refilled and never had an issue.
Whether you do it or someone else, does it take a genius to figure out that the cheapest and easiest way to fix this and ensure that you dont have any issues, is to just have the system flushed?
The brake fluid probably didn't go past the pump (it's a gear pump, so there is no pass-through unless it's turning) - so that means the steering rack is uncontaminated right now.
If he starts it and takes it to someone to have the system flushed - he now has brake fluid throughout the system, including the most expensive part - the steering rack. Depending on the rubber used for seals in the rack that could be quite an expensive adventure.
OP - if you can't do a flush without starting it - have it flatbedded (without starting it) to someone who can. Removing the hose feeding the PS pump and simply flushing a liter or so of Pensotin through the reservoir and hose might be all it needs.. If you or your mechanic is a clever chap (or genius) - you might think of removing the serpentine belt, and after disconnecting the reservoir hose to the PS pump - turn it reverse to normal direction (by hand) - it will pump some PS fluid from the uncontaminated side (upstream from the PS pump), effectively flushing out the pump itself.
Speaking as a non-genius..
Agreed. Not sure this is a DIY unless you are a genius . Probably should get it towed to a good Indie.
A genius might suggest that draining and flushing the reservoir and lines to the PS pump BEFORE starting the engine might be the thing to really do.
this happened to me....on another car by the previous owner....I drained and refilled it twice, then took it to a shop to have them completely flush the whole system. Bottom line, the p/s was toast and had to be replaced. If you caught it before starting and running the car..you might be ok. Good luck man. And let us know!
